I have checked fuses and sensors, replaced the crank sensor and still no spark. Initially it was intermittent non starts then nothing. No check engine light, no codes. Any suggestions? The manual says PCM/ECU but I want someone else's opinion before going that route.
Thank you, it is definitely the key, did a temporary immobilizer override (using the key) n she fired right up. Thank you all so much! That "blinking green key" should be the first thing to check when it "cranks but don't start!"
