What spark plugs from Autozone is recommended? 2004 EX
Old Oct 19, 2022
passive101's Avatar
passive101 is an unknown quantity at this point
Question What spark plugs from Autozone is recommended? 2004 EX
I have a 2004 and I'm getting an error code for a misfire in cyclinder 3. I figure changing the spark plugs is the easiest to see if this solves the problem. Car has 212k miles on it and no idea when the last owner changed them.
autozone says the car came with DOUBLE PLATNIUM. They sell autolites for $6.50. It looks like they have Bosch Iridium for $9.50. the cost difference doesn't matter that much to me. what usually works the best in this car?
Old Oct 19, 2022
FRSam's Avatar
Click Here
Re: What spark plugs from Autozone is recommended? 2004 EX
NGK’s for Honda’s. I used iridium’s in my ‘01.
Old Oct 19, 2022
passive101's Avatar
Cool. I'll see if they have one of those. Any idea how long of an extension I need to change them?
Old Oct 19, 2022
FRSam's Avatar
Click Here
I did mine with a 6" extension and needing basically all of it. Really easy job. I've owned a bunch of cars since I sold it last year and it's still by far the easiest one I've done.
Old Oct 19, 2022
passive101's Avatar
Easiest one you've done? Thank God I should be able to do this project then. I'm handy enough to break things 🤣
Old Oct 19, 2022
Colin42's Avatar
Just be sure to start them by hand, a chunk of rubber fuel line is good for this.
Old Oct 19, 2022
or, if you feel like being fancy, they make a "spark plug socket" that is essentially a deep socket with a rubber insert. You'll need a 5/8" deep socket for your car. They'll be like $8 at autozone
as far as spark plug brand, I'd stick to NGK or Denso
Old Oct 19, 2022
passive101's Avatar
I got a spark plug pulling socket from AutoZone. It has a magnet in it but no rubber. What is the rubber supposed to be for?
This brand is duralast?
Old Oct 20, 2022
so the plug don't fall from the tool and ruin the electrodes gap
Old Oct 20, 2022
magnet does the same thing -- keeps the spark plug in the socket until you take it out. Forgot they make magnetic sockets, too
Old Oct 20, 2022
passive101's Avatar
Alright at least I got the right thing. I lost my spark plug gapper so I'll going to get a new one. Do these iridium ones get gapped to the same number as the regular ones?
Do I need to blow the area out with a can of air? I saw someone on YouTube do that.
Old Oct 20, 2022
FRSam's Avatar
Click Here
I've never gapped my spark plugs (but yes, they'd be gapped the same) or blown out the holes. Maybe I'm just lazy but I've never had a problem that way.
Old Oct 21, 2022
BrotatoChip's Avatar
Super Moderator
If the spark plugs don't fix the misfires, I would guess it's clogged EGR runners in the intake manifold. Pretty common issue with that many miles. This is all assuming your engine has EGR.
Old Oct 21, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Never Bosch. Ever.
Denso or NGK only.
Old Oct 21, 2022
passive101's Avatar
What is EGR?
Old Oct 21, 2022
Super Moderator
Exhaust gas recirculation.
Old Oct 21, 2022
Doesn't hurt to check the gap. Should be .044" (same as OEM gap), and they should be pre-gapped to that. Iridium electrodes are a lot more brittle, so if you do need to adjust the gap, proceed with caution. I had to re-gap one iridium spark plug in the life of my 2002 Civic, and the gap measured .049. To close the gap a little, I put the spark plug in my spark plug socket with a 12" extension, and, with gentle force, rolled the electrode on a chunk of pine 2x4. Worked slowly and checked every so often.
2002blackcivic
Oct 1, 2006 09:42 AM
KidCivic
Aug 9, 2004 04:23 PM
Al_ics
Vancouver
May 16, 2004 09:25 PM
DMX
Sep 23, 2002 11:01 PM
viciousvolpe
May 23, 2002 12:20 PM
