Proper throttle cable position?
Old Aug 19, 2022
zatu's Avatar
zatu is an unknown quantity at this point
I tightened up my throttle cable, but I think that I over did it.
The CEL comes on as soon as the car is started, but goes away if I drive 50 miles down the road - but comes back on after leaving the car off for a hour and starting it. (immediately restarting the car when the CEL TURNED off did not trigger another CEL)
anyone have a proper diagram of how this needs to be? my RPM is sitting right at 950-1k at idle
Old Aug 19, 2022
BrotatoChip's Avatar
Super Moderator
Re: Proper throttle cable position?
What fault code? Is it for high idle?
Re-adjust the throttle cable. It should be just barely loose. As soon as the pedal is pressed it should tighten up and begin opening the throttle body.
Cleft_Asunder
18
Mar 23, 2010 06:31 PM
fly_viet_guy
Jul 22, 2005 01:26 PM
Farage
20
Sep 10, 2004 10:58 PM
gearbox
Aug 10, 2004 08:37 PM
Forum Bot
Engine DIY
May 14, 2004 08:24 PM
