rough Idle Stall and temp fluctuates [solved?]
Old Jul 28, 2022
Katie0917's Avatar
Katie0917 is an unknown quantity at this point
Ok, my daughter has a 04 civic vp.
It started running rough. Low idle, shakes and will cut off at a stand still. All plugs and wires have been replaced and 3 different shops have looked at it.
1 said injectors and they were replaced. Didnt fix anything. So the other 2 said they had no clue, wasn't anything like a head gasket or exhaust, because those test were done. The only thing the scanner will show is a random misfire on cylinder 3 and 4. You can give it gas and it will drive, but after about 15 mins the temp gauge starts to dance. Checked all the coolant and everything is fine there. We are all literally stumped.
Any and All Ideas are welcome!!!
Old Jul 28, 2022
Colin42's Avatar
re: rough Idle Stall and temp fluctuates [solved?]
Iac/egr for idle + misfire.
connect a scanner and see if it shows the correct temp
Old Jul 28, 2022
see if the overflow reservoir for coolant is full or not
Old Jul 28, 2022
Katie0917's Avatar
It is
Old Jul 28, 2022
well, that is a sure sign of a breached head gasket...
if you want to confirm further, there is a video on the first post here, do that test. Other tests will not work for the D17 engines in our cars... Don't waste money on those.
https://www.civicforums.com/forums/3...reference.html
Old Jul 28, 2022
Old Jul 28, 2022
Katie0917's Avatar
Will try this today. Try cleaning both? I am sick of throwing money at it.
Old Jul 28, 2022
the gasket breach will:
  • when engine running, the exhaust gases will go to the coolant and push it through the overflow reservoir
  • when engine stopped, coolant will seep in the cylinders and cause misfire
change the head gasket first
best to change the timing belt at same time if it have been around 100k miles since last change
Old Jul 28, 2022
Katie0917's Avatar
it was a clogged stuck open EGR!!
thank you tons
Old Jul 28, 2022
Colin42's Avatar
Re: rough Idle Stall and temp fluctuates
thank you tons
No problem, the passages in the intake manifold get clogged up. You'll have the manifold off when the headgasket is getting repaired
Freek21
Apr 15, 2018 11:26 AM
cheiscampos90
Feb 23, 2018 06:26 PM
panhandler62
25
Sep 19, 2014 08:51 AM
scout206
Dec 1, 2010 09:29 PM
manukuruvila
Jan 7, 2010 09:50 AM
