Check engine light
Old May 18, 2022
juiceboi123's Avatar
juiceboi123 is an unknown quantity at this point
Check engine light
So I’ve had a check engine light for the last two years, changed one of the o2 sensors under my car to fix the problem, but nothing. I just checked my car “CEN-TECH OBDII” the messages I got were as follows:
“P0134 $011
02 sensor circuits no activity detected ?
Bank 1 sensor 1”
”P0141 $11
02 sensor heater
Circuit bank 1 ?
Sensor 2”
Please help, I definitely do not want to buy a ton of parts and not fix the actual problem. What do you think will work to fix this?
Old May 18, 2022
Colin42's Avatar
Re: Check engine light
What brand were the new o2 sensors?
are you sure the connectors are seated properly?
Old May 19, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
O2 Sensor malfunction codes meaning non-OEM O2 sensor, short or break in the circuit, poor connections at the O2 sensor or PCM or bad PCM. Hopefully something as simple as using cheapo non-Honda O2 sensors or like Colin42 says not properly connected connectors at the sensors.
Advise not waiting so long when the CEL comes on next time. You may have had a reduction in gas mileage over this time of up to 40%. Plus gas prices cost a kidney nowadays.
x3nzox
Jun 4, 2012 11:59 AM
crwtek15
Sep 19, 2011 06:16 PM
Michalo187
17
Mar 8, 2007 02:27 PM
Slow Gold
Feb 12, 2006 12:58 PM
Michalo187
Apr 10, 2005 03:04 AM
