Source(s) of Oil Leak?
Old Feb 9, 2022
rwmj5's Avatar
rwmj5 is an unknown quantity at this point
Mechanic said I would need to replace the valve cover gasket, which fair enough there is some leakage by a bolt or spark plug tube, but there is also a pool of oil under the cylinder plug, that drips all the way down to the transmission. Guessing I need to replace the plug as well? Also some leakage at the front of the engine near the exhaust manifold. Would that be solved by fixing the valve cover leak?
Old Feb 9, 2022
Re: Source(s) of Oil Leak?
valve cover is at the top, any leak there will follow gravity
if you want to know for sure, clean all the engine and drive, check where the oil is coming from
Old Feb 10, 2022
BrotatoChip's Avatar
Super Moderator
Oil on top of the valve cover is almost certainly just from spilled oil when filling. If it were me I would just replace the valve cover gasket, the cylinder head plug cap at the end, and the VTEC solenoid (if applicable). They are all relatively cheap and could be the cause.
pbruske234
Jul 8, 2018 02:21 PM
Pilvr83
Feb 15, 2016 11:59 AM
hokiedad4
Jan 20, 2015 10:19 AM
Tinkerbell_too
24
Dec 28, 2010 07:36 AM
jcpower
Oct 27, 2007 10:47 PM
