Rear main seal too deep?
Old Jan 4, 2022
Millsy088's Avatar
Millsy088 is an unknown quantity at this point
So in the process of removing my rear main seal I accidentally slightly mod the inside of the where the seal seal sits and when installing the new seal with a dead blow hammer it is now crooked with part of it further in and the rest of it flush how bad is this? I'll try and get a photo but it will be hard to show
Old Jan 4, 2022
Re: Rear main seal too deep?
keep pushing and adjusting depth to an even level
you are simply finding out why people pay to other people to do the job.
Old Jan 4, 2022
Millsy088's Avatar
The side that's further in
The side that's basically flush
Old Jan 4, 2022
Millsy088's Avatar
Yep I can definitely see why. I'm not regretting doing it per say but this is really difficult lol
Old Jan 4, 2022
Millsy088's Avatar
So Ive got it close to even by gently hitting the side that's flush further in with the deadblow and a 1/4 extension, so as long as it's even it's okay despite being fairly far in?
Old Jan 4, 2022
reinstall flywheel, clutch, trans, drive for a while and if you don't loose trans fluid, should be ok.
If you loose fluid, then no.
unless yer a professional that do many of them a week, hard to tell what is ok or not, non?
that is the life of a DIY'selfer
you won't know until you need to redo the job...
Old Jan 4, 2022
i did on an old beetle, a golf like car, one of my miatas (which there is a nice tool that fits in there and have the right depth and will work all the time) and never did have to redo, so don't know what would work or not on the civic, never did the job
Old Jan 4, 2022
Millsy088's Avatar
Hahaha well there you go. And I could not for the life of me get the torque wrench at 80ftlbs to not phsycially move the engine, so I used my impact in auto mode which on my wheel lugs does about 78-80ftlbs, is that a big no no or should I be alright doing it like that?
Edit: I also put blue thread locker on all of them if that helps
Old Jan 5, 2022
BrotatoChip's Avatar
Super Moderator
You're supposed to hold the flywheel in place while torqueing the bolts. For me, that usually involves jamming a flathead somewhere to keep it from rotating.
Old Jan 5, 2022
Colin42's Avatar
Do this
Old Jan 5, 2022
Millsy088's Avatar
Yep I did do that but I couldn't get enough force behind the torque wrench to get a click set to 80ftlbs which I thought was strange as it's a pretty long 1/2 drive wrench and I was putting as much force as I could into it so I used the impact and continued as I knew I'd have to wait a few hours for someone to get home and help me put the transmission back in so I could wait for a response from this forum, but even when trying to put in the little 10mm pressure plate bolts at 35ftlbs It took so much force go get the torque wrench to click that I thought I'd done something wrong, so I loosened them and re tightened them and tried to torque them again only to have one of the bolts go from righty tighty to righty loosey, so I'm guessing something was up with the torque wrench or maybe I wasn't holding it right? Now I have to source some new pressure plate bolts and while I'm at it might as well get some new flywheel bolts because who knows how tight they actually were and also figure out what on earth was going on with the torque wrench as I tried it straight after at 35ftlbs on my lug nuts and it was very easy. This is getting more and more fun as I go along
Edit: the pressure plate and clutch were aligned as the clutch alignment tool (that I'd been waiting for 5 weeks to arrive!!) Was freely moving in and out after the pressure plate bolts were already tight
Old Jan 5, 2022
Colin42's Avatar
Something is wrong with the torque wrench, or maybe you were on a weird angle. Make sure you didn't strip out the hole on the flywheel for that pressure plate bolt
Old Jan 5, 2022
Super Moderator
Flywheel bolt torque spec is 87 ft/lbs, 19 ft/lbs for the pressure plate. Don't know where you got 35 ft/lbs.
Trying to hold the flywheel in place with a screwdriver while also using a torque wrench at 87 ft/lbs is very difficult, but it is doable.
thesupersoap33
Mar 15, 2021 02:36 PM
pmanftw
May 18, 2020 03:37 PM
elfred
Feb 14, 2019 10:24 AM
dnmacdon
Aug 30, 2016 10:05 PM
valenzuela
Jan 17, 2007 10:36 PM
