P0139 code [solved]
Old Sep 16, 2021
Bobfrazier5526's Avatar
Bobfrazier5526 is an unknown quantity at this point
P0139 code [solved]
Hello just got a check engine light and the scanner is reading p0139 as a code. I looked it up and I’m seeing it’s going to be a sensor but I’m not sure which one and where it goes. If anyone has done this before all the help out he appreciated. Thanks in advance.
Old Sep 16, 2021
FRSam's Avatar
Click Here
re: P0139 code [solved]
I think it's the O2 sensor that sticks out of the exhaust manifold.
Old Sep 16, 2021
Hmmm i probably should mention that i replaced the up stream af sensor ( it’s a 05 dx so it needs the af) but I don’t remember the code it was throwing last time. Do you think the new sensor failed?
Old Sep 16, 2021
FRSam's Avatar
Click Here
Did you buy an OEM sensor? If not, then it's probably failed.
Old Sep 16, 2021
no it was a denso sensor which is used by Honda from the factory (from what I’ve been told) I could always get a new one under warranty too
Old Sep 16, 2021
FRSam's Avatar
Click Here
Denso is OEM. Where did you get it from?
Old Sep 16, 2021
I got the link from a member on this forum as I know there are multiple fake ones. Even checked with others to see if it’s fake or not.
Old Sep 18, 2021
Okay I’m going to give this alittle bump cause I haven’t got a response. There are 2 sensors attached the the manifold the one just after the exhaust manifold and the one after the cat. I replaced the one just after the manifold but I’m wondering if this code is coming from the other sensor? Any help would be appreciated
Old Sep 18, 2021
FRSam's Avatar
Click Here
Edit: quick search shows that the one under the car is the culprit.
Old Sep 18, 2021
It should be the visible one here behind the heat shield.
hmmm that’s funny that’s the one I replaced. It’s still diner warranty so I’ll try to get a new one
Old Sep 18, 2021
FRSam's Avatar
Click Here
I edited my old post.
Old Sep 18, 2021
https://autoservicecosts.com/obd2-codes/p0133/
https://www.yourmechanic.com/article...ank-1-sensor-2
Old Sep 18, 2021
How to Fix
  1. Check and repair exhaust leaks.
  2. Check wiring problems such as shorted or frayed wires.
  3. Check both the frequency and amplitude of the O2 sensor.
  4. Check for worsening or contaminated O2 sensor, replace if required.
  5. Check for inlet air leaks.
  6. Check the MAF (Mass Flow) sensor for the right operation.
Old Sep 22, 2021
Originally Posted by sdaidoji
How to Fix
Which o2 sensor are we talking about?
Old Sep 22, 2021
BrotatoChip's Avatar
Super Moderator
The fault code is for the secondary O2 sensor. Not the one on the exhaust manifold but further down.
Old Sep 23, 2021
How to Fix
great thank you that’s the answer I was looking for
Old Sep 25, 2021
well I got a laugh out of this and I hope you guys do to. Went online searching how to replace the sensor and I go under the car to look at where it is. Well I go under and I’m looking and looking and looking. Still can’t find it. Look at the video and it’s right under the front sway bar. Well apparently I don’t have one lol. The exhaust is shiney and new after the place where the cat is supposed to be. Good thing I don’t have emissions testing lol
Old Sep 25, 2021
so, previous owner removed the cat?
Old Sep 25, 2021
yeah it looks like he did
NinjaGirl54
Feb 2, 2023 10:28 AM
mikey1
Jun 18, 2015 12:46 PM
Reverb2005
Oct 29, 2014 11:45 AM
What_It_Do
Oct 23, 2011 05:14 PM
stevdirt
May 25, 2006 11:57 AM
