03 hybrid - thermostat replacement
Old Mar 2, 2021
curlywurly's Avatar
curlywurly is an unknown quantity at this point
Any one here ever replace the thermostat on an 03 Civic Hybrid?
Note, it's nothing like other Civics, the layout is different.
Just below the thermostat housing is the coupling box for the HV Battery line, it looks like it may block access for removing the thermostat housing, any tips?
The thermostat housing bolts are easily accessible but looks like I may have to remove more stuff, or is there enough wriggle room to get it out?
Old Mar 2, 2021
BrotatoChip's Avatar
Super Moderator
Re: 03 hybrid - thermostat replacement
Not many of us have much experience with the hybrids, they weren't terribly popular. It may be a good idea to pick up a Haynes (or equivalent) service manual for the hybrid if you intend on doing more work on it yourself.
Old Mar 2, 2021
curlywurly's Avatar
Mine is probably ever rarer, it also has a manual transmission!
I fixed all the other minor issues, and all I'm left with is a sticking thermostat (throws code). I may not fix it, as the car seems to work fine, there is a slight split second hesitance in the engine when the car is getting up to temperature, at the switching point, other than that you wouldn't know anything was amiss.
It definitely has it oddities, 8 spark plugs!
curlywurly
Mar 27, 2021 05:14 PM
CivicHybrid03
Jun 15, 2020 05:39 PM
ChrisBow Pilot
Electrical
Mar 11, 2020 05:14 PM
randomlyrob
Mar 19, 2013 11:30 AM
Besimple1
Aug 23, 2012 10:42 AM
