Fuel pump problem
Old Feb 7, 2021
Courtney Glass's Avatar
Courtney
Courtney Glass is an unknown quantity at this point
Fuel pump problem
2003 honda civic lx sedan auto
Bought the car with a fried ecu. Green key light on the dash blinked constantly. (Alternator bolts weren't tightened) The fuel pump was also jumped on the relay under the glovebox. (Fuel pump wouldn't come on without) Changed the ecu and reprogrammed. Green flashing light went off. Removed the jump on the main relay and fuel pump still won't kick on. All the fuses are good. Relays are good. Checked everything with a power tester, everything has power except where it connects to the actual fuel pump under the back seat. Any ideas or suggestions on what could be the problem?
Old Feb 7, 2021
Re: Fuel pump problem
wiring is fubar, redo it
fuel pump is fubar because of the tricks
did it run when you bought it?
moved thread to proper section of forums
Old Feb 7, 2021
Courtney
It ran like crap because it needed a new ecu. The guy had a paper clip on the relay making the fuel pump stay on constantly as long as the key was on. We changed the ecu, reprogrammed it..it runs better..so we were trying to figure out the fuel pump situation. Took the paper clip out checked a bunch of wires and such. Then this morning it won't start, even with the paperclip in as before.
Old Feb 7, 2021
so, wires were working, pump was working until you started the checks.
you can try to connect the wires directly to the fuel pump to see if it is still working (don't use the current cable, use some other wires - need to find out if either wiring or pump is the issue)
Old Feb 26, 2021
Courtney
Update... been trying to figure it out. The paper clip was actually not right to jump the relay. So now it will start with the paper clip jumping the relay, but without the paper clip, the fuel pump will not kick on. SO fuel pump works.... but why won't it kick on without the paperclip jump?!
Old Feb 26, 2021
Check the wires.
Question - have you programmed the key to new ECU? green key flashing? it cuts fuel off
Old Feb 26, 2021
Courtney
The green key on the dash was flashing before he programmed the key, after putting the new ecu in. Once programmed, it doesn't flash like before. I noticed a yellow and black wire ( ill try to post a pic) I wouldn't think this factory,... its looks to be spliced together. And comes from the main pgm-fi 2 (the blue relay) ill have to check tomorrow exactly where it's connected in there, ... but it splits into 2, and one goes with the rest of the wires to the taped up harness behind the radio and the other goes to another wiring harness to the right,... I will take more pics tomorrow, since it got dark. I'll post what I have. Idk if this has anything to do with the problem we're having
Old Mar 1, 2021
BrotatoChip's Avatar
Super Moderator
Check number 6 fuse (15 A) in the under hood fuse box?
It's no surprise there's a splice like that, what is surprising is that there's nothing covering it. It needs taped up so it isn't shorting out.
ArtimisRawr
Electronics
Aug 28, 2020 03:05 PM
David Mckenzie
Nov 3, 2019 04:35 PM
lionel_lampkin
Oct 22, 2012 02:53 PM
jun10r27
Dec 12, 2009 08:32 PM
aspencer80
Jul 28, 2009 12:41 PM
