Code P0340 Engine overheat then stalls
Old Aug 5, 2020
Peter Sultana's Avatar
Peter Sultana is an unknown quantity at this point
Have a long commute in Tucson (over 1 hour each way). Car runs fine with A/C on for first part of commute. On return trip home, engine overheats and stalls about five minutes from house. Code is P0340. This has happened three times at the same location of my commute. Have replaced Camshaft position sensor but continues with problem. Other solutions may include timing belt tensioner but have looked at repair videos and they look difficult for me. Help!
Old Aug 5, 2020
FRSam's Avatar
Click Here
Re: Code P0340 Engine overheat then stalls
Did you replace with a genuine Honda sensor?
Not sure why it would be the timing belt tensioner. A faulty sensor makes sense but I don’t see how replacing the tensioner would make a difference. It’s just a little spring-loaded one from what I can remember.
Old Aug 5, 2020
Thanks for the response. When I googled the code it did not mention the tensioner. That solution came from an auto parts store. Looks like a wire/connector problem due to the long drive/heat.
Old Aug 6, 2020
BrotatoChip's Avatar
Super Moderator
I would focus on the engine overheating issue first.
Why is it overheating? Low or leaking coolant? Coolant overfilling the reservoir but radiator is low?
Old Aug 6, 2020
Originally Posted by Peter Sultana
engine overheats
What do you see that makes you say this?
Old Aug 7, 2020
Replaced with a Direct Import brand sensor. No change in the problem, still stall and overheats during last 5 minutes of return commute. After leaving engine off for 10-15 minutes, engine returns to normal operation and heat range on gage.
Old Aug 7, 2020
Temperature gage goes from middle of range (normal) to just under high and engine loses power and stalls. This is during the evening commute after about 1 hour of operation on the freeways in Tucson (100+ degrees).
Old Aug 7, 2020
No leaking and overfilling of reservoir, so no coolant leaks.
RefUF
114
Sep 29, 2022 01:10 PM
willban1
Apr 25, 2016 06:28 PM
j.squared
22
Mar 17, 2015 02:05 PM
02civicsi02
Dec 4, 2010 02:36 PM
Rapom
Nov 10, 2008 03:57 PM
