Sluggish acceleration when AC is on
Old Feb 6, 2020
felicianojerome's Avatar
felicianojerome is an unknown quantity at this point
The acceleration of my car is sluggish whenever I turn on the AC. It's like the engine is misfiring when I stepped on the gas pedal coming from a complete stop and it's like the car will stall. But when I'm not using the AC, it runs perfectly.
Newly replaced timing belt, air filter, spark plugs and fuel filter. I already clean the throttle body also.
What other things should I need to check/replace? Thank you.
Old Feb 7, 2020
BrotatoChip's Avatar
Super Moderator
Re: Sluggish acceleration when AC is on
Check engine light on? Fault codes?
Old Feb 7, 2020
No check engine light and fault codes either
Old Feb 7, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Maybe your compressor is on its way out and creating excess drag?
Old Feb 7, 2020
Slumpertcivic's Avatar
AC circuit will alter the idle valve.
Free test would be to unplug the AC clutch and take for a test drive. If it still feels down in power with AC on but clutch unplugged it’s not a compressor issue.
Old Feb 10, 2020
Might give this a try. Thanks.
Old Feb 10, 2020
Are bad ignition coils a possible cause?
Old Feb 10, 2020
Super Moderator
Possible, but you would likely see a fault code.
Old Feb 12, 2020
Just an update on this guys.
I've checked the throttle body again and found out that it is dirty AGAIN! I've just cleaned it a month ago. Tried to clean it again and then boom! The car runs perfeclty again while AC is on.
My question now, why is my throttle body gets dirty quickly?
Old Feb 12, 2020
Global warming, quality of the air filter, cracks in the intake resonator?
Aged idle control valve might “jam” up easier than a new one.
aklysheiko
Aug 7, 2018 05:35 AM
carlinag13
Jun 16, 2014 01:43 PM
Luke G
Sep 14, 2007 01:24 AM
mackin
Oct 24, 2005 10:15 PM
pnoyster2k1cvic
31
May 11, 2004 06:24 PM
