Oil Leak
Old Jan 9, 2020
devinkkperry's Avatar
devinkkperry is an unknown quantity at this point
Oil Leak
Replaced the valve cover gasket but I’m still losing oil. Can anyone tell where the problem might be from these pics?
Zooming in
on the area
so you know where this is.
Transmission
Oil pan
Old Jan 9, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Oil Leak
If no visible droplets of oil, then you arnt losing enough oil to notice, from leaking.
Probably burning oil.
-Check pcv valve
-try either 5w30 oil, or, 5w20 with Lucas HD
Old Jan 9, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Oil Leak
The camshaft end plug is a common oil leak and is located on the side of the head near the EGR valve. Red circle in attached is the location.
Also, minor detail but you are missing a bumper/grille clip near the hood latch and you could use a new ground strap (quite noticeable in your 3rd photo).
Old Jan 11, 2020
Wankenstein's Avatar
Re: Oil Leak
As stated prior most likely an end cap. Could also be valve cover too. Personally, I use rtv sealant as little as possible but I've found that applying rtv to the end cap o-ring tends to help compared to it not being applied when installing a new end-cap. I have even reused an end-cap with rtv applied and it sealed it completely... that was 15k miles ago. Just have to be careful and apply only a thin coat of black rtv or Hondabond on the end-cap o-ring and do not glob it on. The goal is to avoid any overage of rtv from getting into valves or camshaft.
Also, personally I prefer to replace the end-cap with the valve cover off to ensure the two tabs (legs) of the end cap don't break off during removal, or if they do I will be able to find them before starting the engine. It's a bit of work to remove all items theout of the way to eventually remove the valve cover but once the valve cover is removed it's a good time to replace the valve cover seal, check intake and exhaust valves clearances, replace spark plug hole o-gaskets.
Old Jan 11, 2020
Re: Oil Leak
@NDNV @HR Puffinblunts
Thanks! Looks like you were spot on. I assume you're referring to this:
Last edited by devinkkperry; Jan 11, 2020 at 07:26 PM. Reason: Forgot to attach photo
Old Jan 11, 2020
Colin42's Avatar
Re: Oil Leak
Then clean the engine thoroughly, take it for a drive and then pop the hood and look for the source of the leak
Old Jan 11, 2020
Re: Oil Leak
That's it. A common oil leak source for these engines.
Old Jan 13, 2020
NDNV's Avatar
Re: Oil Leak
Yes, that's the source of your leak.
Niko
Aug 15, 2016 10:14 PM
vdubbin95
Dec 2, 2015 01:52 PM
hokiedad4
Jan 20, 2015 10:19 AM
civicpapi
Jan 6, 2010 07:19 PM
02civic21
Jun 19, 2007 11:52 AM
