Engine Oil Leak - 2005 Honda Civic EX
Old Dec 29, 2019
devinkkperry's Avatar
devinkkperry is an unknown quantity at this point
I’ve been trying to locate an oil leak because I’ve been going through a few quarts of oil every week to maintain the oil level.
Are these areas the culprit? And if so, does this likely mean I need to replace the head gasket or...?
Also, I’m having an overheating problem when I’m idle for too long. Is this likely related to the oil leak or is it a separate issue?
Old Dec 30, 2019
Colin42's Avatar
Re: Engine Oil Leak - 2005 Honda Civic EX
That certainly isn't helping, but it's most likely burning it if you're not seeing anything underneath the car. Get a valve cover gasket kit and that will have the tube seals. The oil burning is most likely the oil rings on the pistons
As for the overheating at idle, do the fans work? Coolant level good and bled properly?
Old Dec 30, 2019
The fans work fine and the coolant level is topped off. In fact it doesn't appear to have depleted at all in months, I suspect it's just sitting in that reservoir not being taken in by the radiator. What do you suggest?
Old Dec 30, 2019
Colin42's Avatar
Fill the rad. Not rocket science.
if coolant is getting pushed out of the rad and into the reservoir, you have a blown headgasket
Jrhuntington
Jun 16, 2017 04:33 PM
Steevo
Oct 28, 2011 09:38 AM
Muirsy
Oct 29, 2009 05:09 PM
7thgenchris
Apr 25, 2009 09:50 PM
fi dx
Engine Swaps
Feb 23, 2005 11:33 PM
