Camshaft won't turn, broke timing belt
Old Oct 25, 2019
brokercar's Avatar
brokercar is an unknown quantity at this point
My timing belt went on my Honda Civic 2001 LX.
I was going down a hill, maybe at 45mph when it happened. Cranked it over a bunch trying to diagnose it. Realized my timing belt was snapped
I took things apart, and was gonna do a compression test etc. but couldnt get the camshaft to rotate at all. The crank turns just fine.
I took the head off today
I bend at least two intake valves.
My question is.... could the bent valves be whats stopping the camshaft to turn.... or is it likely I effed up the camshaft too?
Is it likely that I damaged the pistons at all? Crank turns fine.
I'm also wondering why my belt snapped (it wassnt in shreads)
I did crash the car, head on last month. Fixed her up, new radiator etc. Ran like a top for a few days.
I did the timing belt like 2 or 3 years ago.... my buddy effed the tensioner bolt's female threads on the block (the ol' righty loosey deal) So the tensioner is in there well enough but has a little wobble to it.
Old Oct 25, 2019
GolNat's Avatar
Prelude Owner
Re: Camshaft won't turn, broke timing belt
How does the tensioner spring look? Was the tensioner replaced when the timing belt was done?
The bent valve is probably keeping the cam from rotating. Valves usually take the brunt of the force.
Old Oct 26, 2019
BrotatoChip's Avatar
Super Moderator
A loose belt tensioner sounds like a disaster waiting to happen. It could've caused the belt to go off center and rub things. I would've expected to see damage though. Also, what brand belt did you use?
Old Oct 26, 2019
Slumpertcivic's Avatar
Maybe the valve stem itself bent as it was between a piston and a cam lobe thereby jamming into the valve guide.
I would expect the camshaft to turn backwards some if that was the case,
You pulled the head off, easy enough to pull the rockers off and see if the cam turns easily at that point. If it’s still jammed turn the head into a herb garden or something.
Ariah J. Davis
Jul 20, 2015 07:15 AM
159
Jul 5, 2015 09:54 PM
thewal
27
May 26, 2011 05:26 AM
95EX
Jun 30, 2010 05:41 PM
thatoneguy
Aug 15, 2006 06:36 PM
