Issue after using seafoam in civic
Old May 30, 2019
jonathan_oakley's Avatar
jonathan_oakley is an unknown quantity at this point
So i have a 2002 civic dx sedan 1.7L. Was getting a bit of black/blue dark smoke when hitting the gas hard, and burning oil a lot. I took the spark plugs out and added about 0.5 ounces of seafoam in each hole and let it sit for an hour then turned it over a few times to expel the fluid hoping it may free some gummed up rings. I also put about 1/3 of the can in the gas tank. I put the plugs back in and fired it up and let the solvent idle off for about 20 minutes. But now my exhaust is noticeably louder? There's a stainless steel header on it so no converter to be affected. Could this be related or just a coincidence? It seems to be louder near the front of the car not near the muffler. Was thinking maybe it affected the manifold gasket? I can see any issues when looking at it.
Old May 30, 2019
Slumpertcivic's Avatar
Re: Issue after using seafoam in civic
Might be as simple as a chunk of gunk broke off one or more valves so now it’s not seating evenly.
If the gunk is even, the valve can still make a reasonable seal, but knock loose a section and now there is a partial gap where the gunk was.
Oil burners have lots gunk..
Old May 31, 2019
What can i do to help this issue?
Old May 31, 2019
Do a compression test to see how things are working?
Old May 31, 2019
It's likely just in your head LOL
Old May 31, 2019
I hope so lol
Old Jun 1, 2019
mac25's Avatar
Dr Krieger of Modification
It's not really a good Idea to try to clean an engine which is burning oil, imo.
The burning is due to gaps in an old engine, piston rings, combustion chamber walls and valve seals mostly. These larger gaps leak oil into to combustion chamber.
When you clean it any oil build up/carbon build up which might have developed over the gaps is removed; like removing a scab, without the scab you may bleed more/leak more.
The sound is probably because the old exhaust system was rusty and full of gaps, but now the carbon has been cleaned out of the system, letting exhaust flow through the gaps.
Old Jun 2, 2019
My flange below my header actually has a small crack in it, explains the loud exhaust at least lol
Gmwirth
Jul 19, 2021 07:24 AM
91LXdriver
Dec 1, 2016 01:24 PM
Honda_Problems
53
Feb 5, 2015 08:38 AM
cooljoe123
Apr 15, 2011 03:03 PM
bassg26
Mar 26, 2007 11:25 AM
