head gasket replacement project
Old May 6, 2019
noquacks's Avatar
noquacks is an unknown quantity at this point
People,
removing the head, and wondering if I should remove cam sprocket before removing head from engine. Is there a place where one could place an open end wrench on cam to unbolt the sprocket? Maybe the sprocket should stay put?
Thanks, people.
Old May 6, 2019
Re: head gasket replacement project
I don't remove the cam gear unless it NEEDS to be removed.
Old May 7, 2019
Slumpertcivic's Avatar
Loosening the sprocket is easier if the belt is still on.
Lots of people have had engine failure due to contaminates and or improperly tighening that bolt back up.
So if your going to pull it, be sure to use brake cleaner and blue loctite and proper torque wrench when you put it back together.
EFkipp
Oct 12, 2015 03:45 PM
Rhonda1
Aug 11, 2014 09:03 PM
M00n3at3r
Bolt-on Engine Performance
Jun 2, 2014 09:41 PM
nsrhonda89
Jan 20, 2014 12:03 PM
BlueBallz94
Feb 13, 2010 08:42 PM
