TDC is this how it looks like?
Old Mar 12, 2019
elfred's Avatar
elfred is an unknown quantity at this point
Hi Civic forums!
So I am doing timing belt ,ac/ps belts water pump and tensioner replacement.
Little that I know that when pull all the belts but done TDC prior, so I forgot to pull the spark plug off, silly for an hour and an hour doing TDC agains compression( is this bad? idk) just only now that I realized that I have to make sure if #1 cylinder is on top dead center, so I make a lengthwise 4 rolls of paper and stick it in each spark plug hole.
Is this how it looks like if properly TDC it, btw I have already pull all the belts and pulleys and crank sprocket.
Need you guys a awesome advice please.
Thank you in advance!!!
Old Mar 12, 2019
BrotatoChip's Avatar
Super Moderator
Re: TDC is this how it looks like?
Yes but you need to be more accurate. Look on the end of the camshaft sprocket, there should be two lines that you need to match up with the head and then another mark that says "UP". Step 13 in the DIY link below explains it as well.
https://www.civicforums.com/forums/1...t-diy-2-a.html
Old Mar 12, 2019
elfred's Avatar
Hello Brotato!
Thank you for the reply!
Yeah I did that already before I pulled the old timing belt, all marked on engine and on both cam and crank sprocket are TDC correctly.
It is just that I forgot to pulled the four spark plug, so silly me of doing TDC procedure agains compression, would this be bad?
Is there any procedure to confirm TDC on this cam and crankshaft sprocket ? or is this all?
Thanks in advance!!!
cheers!!!
ELFred
Old Mar 13, 2019
Super Moderator
Ok, so you have the camshaft at TDC. You can use your method to get the crankshaft at TDC as well but if it were me I'd put the lower timing belt cover back on then slide the pulley over top. The picture below shows timing marks on the cover and crankshaft pulley that should line up.
Old Mar 13, 2019
elfred's Avatar
Nice awesome thanks, Smart! I'll do that.
Cheers!
ELFred
scout206
20
Dec 6, 2014 12:57 AM
J.P.M.
Sep 15, 2014 11:02 AM
layin-lo
Jul 20, 2014 11:27 AM
wastintime
Jan 1, 2014 09:46 PM
bikes_and_plane
Jul 15, 2013 05:00 PM
