2005 Civic - Just cranks but no start
Old Mar 9, 2019
robert99ranger's Avatar
robert99ranger is an unknown quantity at this point
Working on an 2005 Civic. In the past month or so it has had issues starting. It just cranks and cranks but doesn’t want to start. Has a brand new battery,
no check engine light, timing belt has been replaced within the last year. If I put just a shot of starting fluid into it, it starts right up. When you turn the key on, you can hear the fuel pump run for a couple seconds. Car runs great after it starts. It’s intermittent which is agrevating. Thoughts? Was thinking crank position sensor. Thanks
Old Mar 9, 2019
mac25's Avatar
Dr Krieger of Modification
Re: 2005 Civic - Just cranks but no start
Sounds like a fuel related problem then.
You'll have to find where it is failing.
-check fuel pressure at the rail.
-then check for pulse at the injectors (you can use a simple and cheap test light)
Ted-04
Feb 5, 2019 01:52 PM
Kristinb737
Apr 18, 2017 01:06 PM
tadman
Engine start problems
Jan 2, 2014 08:20 PM
Harpo
Aug 7, 2010 03:29 PM
andymanv
23
Feb 19, 2007 02:55 PM
