Any easy way to check TB tensioner torque?
Old Feb 21, 2019
sidefly's Avatar
sidefly is an unknown quantity at this point
Head gasket repair brain fail. Sorry for this idiot question!!! Any easy way to check the tensioner once the head cover and belt covers are on? ...and nearly everything else on too???
So I got 99% of the car put back together last night... I’m working today and mentally walking back my work... I don’t remember torquing the timing belt tensioner. I remember pulling this set pin when you are all done, but I don’t recall torquing the damn bolt??? Did I do it or not? ...major *** pain to check now.
You put the timing belt on, torque the damn tensioner bolt, attach the tensioner spring, then pull this grenade pin. I know I did the spring and pin.
Old Feb 21, 2019
Mojo20032004's Avatar
Mojo20032004 is an unknown quantity at this point
Re: Any easy way to check TB tensioner torque?
Unfortunately there isn't any short cuts other then breaking the lower timing cover off and getting the the bolt.
Old Feb 21, 2019
sidefly's Avatar
Any chance I can pull off my AC and alternator belts, then remove the crank bolt and pulley and pull the bottom cover off without removing the upper cover? Except for that middle bolt. -garage door syndrome! did I close it, I don't know!!!
Old Feb 21, 2019
sidefly's Avatar
So just to follow-up on this... You can indeed take off the belts and crank pulley, then remove the lower cover belts and sneak a crescent wrench up to validate the bolt is actually tight. I was even able to remove the tension with a 6mm allen wrench at the same time. So, if you are a super idiot like me it is recoverable without taking everything apart again. BTW, mine was already tight. :/
Do yourself a favor and make a checklist of completed items so you don't have to worry.
Old Feb 22, 2019
Colin42's Avatar
better to always double check and be sure
Wildcat445
Jul 25, 2019 02:41 PM
creaker2
Engine DIY
49
Jun 5, 2019 07:15 AM
Cleft_Asunder
Engine DIY
65
Oct 8, 2018 04:56 PM
SkullinsideSkin
May 27, 2011 12:04 PM
streetglower
Engine DIY
Mar 3, 2008 03:31 PM
