Started Car With Engine Not Correctly Timed
Old Jan 10, 2019
Tiznut's Avatar
Tiznut is an unknown quantity at this point
So we changed ting belt in 2001 Civic LX a/t.....we were off time put everything back together and tried starting car ...car never started realized timing was off no compression I assumed I bent the Pistons or valves but haven't actually verified is there a chance if I just fix timg of car that it would be ok ar am I screwed
Old Jan 10, 2019
guitarsnlikker's Avatar
guitarsnlikker is an unknown quantity at this point
Re: Timing belt question
You can try it. If they are bent they are bent. If not, which is POSSIBLE, it will be oK. You can always do a leak down test if you know how and have equipment to verify.
Old Jan 10, 2019
mikey1's Avatar
Re: Started Car With Engine Not Correctly Timed
depends how far off,
if it only one tooth you might be okay, anything more then that is risky
ronno5957
Feb 10, 2015 06:46 PM
pro-cognizant
24
May 26, 2014 09:37 PM
GYTR_YAMAHA
Dec 18, 2012 07:53 AM
lilhuff
Nov 18, 2011 06:11 AM
Pongster
Apr 12, 2002 10:03 AM
