Getting ripped off?
Old Dec 17, 2012
GYTR_YAMAHA's Avatar
GYTR_YAMAHA is an unknown quantity at this point
Getting ripped off?
I was working on my car for a few weeks and couldnt find the problem, so i took it to a shop that is very farmiliar with hondas, one sixx milwaukee, it ended up that my timing belt jumped 5 teeth, so they say. he told me that it may have bent valves, im not sure if timing like that would bend valves. what do you guys think?
He also told me that he would trade me the gsr i have in my civic for his JDM b16 with what he says has 80k on it. let me know what you guys think.
Old Dec 17, 2012
Stock 99's Avatar
Re: Getting ripped off?
If it jumped 5 teeth you wouldn't be driving it because your valves would be bent and you would have 0 compression.
Old Dec 17, 2012
Did you DRIVE the car to the shop?
5 teeth off would either not run at all, or barely run with not enough power to safely drive.
5 teeth may or may not be far enough to do damage.
Each engine seems to be a little different as far as how far off they can get before making valve contact.
Easy to figure out if it bent valves, but takes some time and work.
Easier to just stick a timing belt on (correctly) and see if it runs, and how well it runs.
Hard to prove if THEY bent the valves or not through carelessness or whatever. Yes, it can happen that way.
What's a GSR and why would he want it?
Maybe he wants your engine and thinks you're a sucka.
Old Dec 18, 2012
No i towed the car to the shop it doesnt run. I have a b18c1 sawp in my civic he wants a gsr(mine) for his car and wants to swap his JDM b16 into my car for $450... Currently baragning still..
Old Dec 18, 2012
marek91's Avatar
marek91 is an unknown quantity at this point
Is he going to pay you the 450 to do it ? if so not bad, but i other wise wouldn't even consider
I dont know what the prices are for motors around you but a GSR here matched with an LSD will go for about 2500 - 3k (not including the install)
a B16 with LSD tranny will go for maybe 1500 (not including install)
alinaray
18
Aug 24, 2015 01:04 PM
wcodyd
Exterior
Jun 22, 2015 11:24 PM
bluedoggy1
Jun 20, 2015 11:25 PM
blowhole
Mar 20, 2002 08:43 PM
ricerocket
Feb 22, 2002 09:02 PM
