D17A1 with vtec top cover?
I was given an 05 ex coupe se with something funny going on. It is a D17A1 block with the plastic cover on head that says vtec. Seems odd to me since this isnt supposed to exist. Motor was swapped recently and not completed. Upon completion, its in limp mode with issues. Car was a egr cali compliant, swap is a non egr A1. What confuses me is the head badge. Scratching head. Any ideas how this happeded? Head swap? So confused.
Re: D17A1 with vtec top cover?
Like the little plastic coil cover?
Probably came from the original engine and was slapped on because the swapped engine didn't come with it.
It's in limp mode because it's a VTEC car with a non VTEC engine
Forgot to mention, i supplied motor for swap, not realizing it was an A1 since it had a vtec badge on the head. So both original and swap motor had the vtec badge. Im thinking none of this mattrrs since anti freeze is bubbling out of open radiator so i think it too has a bad head gasket. The original had a bad gasket with an external leak. Any way to tell what head is on this motor? It is a PMR-HA-7
Unfortunately original engine was scraped. Not real happy about that right now. Egr to non egr swap isnt working so well. Plus A2 to A1 is making my hair turn real gray. Should have fixed the original engine. Would have been ahead. Thats how we learn right?
Does the new head have the vtec solenoid on it?
You could have made the new engine have egr, just needed to swap some parts over
huh, if you had kept the original head, you could have simply installed it and gone around the ECU asking for a VTEC (in case your current one is not a VTEC head).
this below is VTEC rocker arms
Attachment 100366
the ones below are the lobes for one cyclinder - there will be 4 of them in a VTEC camshaft.
If yours have only 2 lobes, it's a non-VTEC camshaft. If it have 3 lobes per cylinder, it's a VTEC camshaft.
Attachment 100774
Attachment 100366
Attachment 100774
i dont remember seeing one... i think the po of the donor car put the plastic cover on it just to screw with a dumb dumb like me. It worked! Im thinking of starting over. Pull out the a1 (after i determine it has a bad hg) and put in a A2 egr engine. I have my eye on one at my supplier i can get for dirt cheap/free. Chalk this up as an expensive lesson.
Attachment 100366
Attachment 100774
Attachment 100366
Attachment 100774
i guess i could pull this A1 head, replace with a reman A2 head, get a EGR thermostat housing and im gasket, plug everything in and go with it. That way, i dont have to pull 2 engines.
CiViCAGUY
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Jul 26, 2014 07:18 PM
