P1259 vtec really sucks
Old Sep 25, 2018
310civicEX's Avatar
310civicEX is an unknown quantity at this point
I got fresh oil, switched 2 solenoids and 2 vtec oil sensors and 2 vtec housings... still get p1259... only other thing could be fuel pressure? So either the fuel pressure regulator or fuel pump could have low pressure?... the vtec wire is cut and twisted on the harness side.
Old Sep 25, 2018
310civicEX's Avatar
Re: P1259 vtec really sucks
Old Sep 25, 2018
Colin42's Avatar
Definitely fix all sketchy wiring
Old Sep 26, 2018
Nope. Fuel is unrelated to anything vtec.
Fuel problems would give you very different symptoms and codes.
Old Sep 26, 2018
cheap one... fix properly the wiring. go from there
Old Sep 27, 2018
310civicEX's Avatar
that's strange because the service manual says absent low oil...good sensor and good solenoid could be low fuel pressure.
Old Sep 27, 2018
Colin42's Avatar
are they aftermarket parts?
Old Sep 27, 2018
Slumpertcivic's Avatar
VTEC needs to monitor high pressure oil being present when selenoid is closed and no high pressure oil moments after signal is sent to selenoid to open.
This is completely different circuit than the low level oil sender.
Honda engineers are pretty smart and I have no doubt they also built in other safety features.
Old Sep 27, 2018
That should read "could be low OIL pressure".
But is it?
There are many different possible causes for the vtec code.
Do you understand how the valve is suoopsed to work, and what the computer has to see in order to stay happy?
Got FF data? What rpm was it when the code set?
What all work has heen done to your engine recrntly, again? Refresh my memory.
Old Sep 27, 2018
310civicEX's Avatar
But is it?
​​​​when put the intake back on I'll check live data to see what rpm it comes on at..I wanna say 4500...
Old Sep 28, 2018
I don't care what RPM the vtec turns on at.
I want to know what the RPM was when the fault code set . THAT is what Freeze Frame data is for.
If you have live data, does it show VTEC on/off?
Does it also show the vtec pressure switch on/off?
Old Oct 3, 2018
310civicEX's Avatar
My live data isn't showing vtec stuff..
I got it all together. .is there a way to check if it's good? I reved it up to 5500 rpm and the light never came on.
Old Oct 3, 2018
It won't turn on vtec without a VSS input. That means you have to be driving, or have the front wheels off the ground to it can be in gear with wheels spinning.
I might assume it must have set the code at high rpm when vtec would have been activated?
I have used test lights and voltmeters to monitor the vtec command and response .
Did you have the cylinder head off this engine just before the vtec code came up?
alkb1666a2
Feb 20, 2010 08:45 PM
pmontoya4321
Nov 4, 2005 08:29 AM
02fpcivic
Dec 3, 2003 12:16 PM
R3DL1N3
Aug 16, 2003 11:39 PM
2k2civicballer
Apr 6, 2002 11:36 PM
