2004 Civic EX giving a hard way to go
Old Apr 19, 2011
66 Big Block's Avatar
66 Big Block is an unknown quantity at this point
I am new here so please be gentle. Here is the scoop:
My wife had to drive my son back to college last week. It is about a 2 hour drive with no stops made and no problems with the car.
She stayed there for about a half hour then left to come home. The drive was uneventful until she got about a mile from home. At the point she said the temp gauge shot straight up to hot, as far as it would go. She said there was the smell of anti freeze at that time.
I checked the car over and nothing in regards to the heating and cooling system and everything appears fine. So I go to take the car for a ride. Temp gauge went to just below the mid point and stayed there. But I did notice something else it started to do.
When the car is in motion the heater will blow heated air. The moment you stop, like at a traffic light, it stops blowing hot air and then blows cold air. I am expecting the heater core might be shot
car has about 129000 miles on it and has never had problems outside of tires, brakes and regular oil change.
Any advice?
Old Apr 19, 2011
Re: 2004 Civic EX giving a hard way to go
go to a shop and ask for gases in the coolant test - most likely head gasket leaking combusted gases to the coolant system.
If gases detected, need to change the gasket and check head for uneveness.
Also, change the fonts on your post - it's just hard to read.
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
Strychnine
Aug 15, 2001 07:07 PM
Strychnine
