Won’t idle after charging battery
Old Jun 16, 2024
Terrydunn1's Avatar
Terrydunn1 is an unknown quantity at this point
2004 civic. Battery was completely dead. I put a 10 amp charger on it and forgot about it for 3 days. Now it starts and immediately dies. Giving it throttle doesn’t help, neither does holding the key in start position. Have I burned something out? If so, what could it be?
Old Jun 17, 2024
BrotatoChip's Avatar
Super Moderator
Re: Won’t idle after charging battery
Any fault codes?
Old Jun 17, 2024
Terrydunn1's Avatar
I don’t know how to check them
Old Jun 17, 2024
FRSam's Avatar
Click Here
By using a code reader.
Take your battery somewhere like autozone and get it load tested. If it stayed dead and then got cold, it probably swelled which makes it useless.
Old Jun 17, 2024
Terrydunn1's Avatar
It seems fully charged. Starter turns engine fast
it starts immediately and then dies
Old Jun 17, 2024
chargers nowadays have a function to maintain after the battery is charged, if yours is new, it should not cause issues with battery
Old Jun 17, 2024
Terrydunn1's Avatar
im going to get a new battery tomorrow. But I really don’t expect it to solve my problem
Old Jun 17, 2024
checked fuses? Did you change any engine sensors? Timing belt at right timing?
I would have expected to see some codes in this case too.
Old Jun 17, 2024
Terrydunn1's Avatar
im going to have to get a code reader. It was running great when I parked it. It acts like it loses fire as quick as it starts. I’m going to try a new battery tomorrow. The old one went down overnight. I checked all the fuses under the hood. Is there one in the interior panel that could cause this?
Robertbuehler
Dec 25, 2022 10:00 AM
Typh
Jun 6, 2012 02:24 PM
toddhanna
Electrical
May 29, 2011 09:48 PM
takumi
37
Sep 20, 2004 04:29 PM
Blckcivic01
Mar 19, 2002 11:00 AM
