dome light causing noise?
Old Feb 13, 2023
mkeschinger's Avatar
mkeschinger is an unknown quantity at this point
I have been hesitant to ask, mainly because I didn't know how to phrase it without sounding like an idiot....
When I open the door - the dome light goes on. when i sit down I hear a light whining as the light dims through the speakers. Instinct says ground, but why would it make a whining sound through the speakers.....
Thoughts?
Old Feb 14, 2023
Colin42's Avatar
Re: dome light causing noise?
Door harness wires could be shorting
Old Feb 14, 2023
I wouldn't think there would be a connection, unless the ground wire to the car itself is funky.... Hmmmm Would that cause it?
Old Feb 14, 2023
Colin42's Avatar
There's ground wires in the door....
Old Feb 14, 2023
I figured that. is it the same ground wire that connects to the radio to transmit it over the speakers? Honestly, it almost sounds like an old tube from a tv or amp cooling off. It's the weirdest thing. Either way, I will check the ground wire in the door. I assume its the button that tells the car the door is open or closed?
Thanks for the direction!
M
Old Feb 14, 2023
Colin42's Avatar
Ground is ground. However the negative from the speakers is supposed to go to the head unit, not to ground.
Old Feb 14, 2023
That's what has me perplexed. The light fades like its supposed to, but it makes a noise through the speakers as it is doing so. So the ground must be connected somewhere to the the radio some how..
Wait, I may have the answer. One of the rear speakers isn't work... What if in the back of the radio, the rear speaker is connected to the ground on the radio.....
I'll have to check that in the am!
Old Feb 15, 2023
pull the door switch for the interior lights and check the wiring
Old Feb 15, 2023
What is the door switch for the interior lights? I know the tumbler turns them on when I use the key, and the button to show the door open turns them on. Sorry, still learning.
M
Old Feb 15, 2023
there should be a switch in the chassis side close to the door hinges.
Did not know the key would turn them on, that is for newer models, so there is a wire going from the door to the lights too, which could get damage after so many times the door is opened/closed. Check also the wires that go from door to the chassis around the hinges.
nanciq
Jun 17, 2012 02:10 PM
adambomb
Feb 15, 2009 01:53 AM
abmerop18
Oct 24, 2004 10:51 PM
6fingaz
Sep 1, 2003 01:45 AM
Diznavis
Feb 7, 2002 06:54 PM
