Sponsored by:
Sponsored by: CARiD
Buzzing from dome light
Old Oct 24, 2004
abmerop18's Avatar
Jam out with your clam out.
does anyone else's dome light buzz when they open the door and it is on? mine makes a weird buzzing/ringing noise. do i need to get a new bulb then?
Old Oct 24, 2004
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
I think thats normal, mine does that too
Old Oct 24, 2004
k-man's Avatar
k-man is an unknown quantity at this point
its not normal, my BRAND NEW 04 did it a day after i got it, wasnt too impressed
but brought it back to the dealer, they fixed it up, doesnt do it anymore...............but damn was it annoying!
get it fixed, there is definately something wrong
Old Oct 24, 2004
robbclark1's Avatar
Retired suspension supermod.
the rear light buzzes on mine. I just turned it off.
Old Oct 24, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
maybe faulty wire connection....go get it checked, u don't want it to start a fire
Old Oct 24, 2004
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
same here
Old Oct 24, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Some bulbs buzz. Some don't. My factory bulb buzzed, then I replaced it and the noise went away. I replaced that bulb with a colored bulb and the colored bulb buzzed. Colored bulb burned out and I replaced it with another colored bulb from the same company. That bulb doesn't buzz.
Old Oct 24, 2004
jfan's Avatar
Mine buzzes because I put in replacement bulbs that were of the wrong size. I just have not put the factory ones back in yet.
Old Oct 24, 2004
hustlelikem0fo's Avatar
that buzzing isnt exactly buzzing. if you listen close its the nawzzz spooling up creating that buzzing sound in your dome light
Old Oct 24, 2004
dalaw's Avatar
Bone Stock!
something inside my driver side dash board buzzes after my dome light goes off. Dont know if it is caused by my aftermarket alarm or its honda's problem.
Old Oct 24, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
haha you gl00b your **** is busted.. Easiest fix is to take it to honda..
Old Oct 24, 2004
He accidentally wired his nawz purge valve into his dome light
Maybe if he hadn't gotten his dcsports header with his t4 turbo dominac and aic controlled air intake, he'd be okay.. but he had to go fast and furious...
Old Oct 24, 2004
he was purging the nawz out of his dome light...... i tried to tell him to run his purge lines to his washer nozzles but noooooo, he had to run them to the dome light whcih he now fvcked up
Old Oct 24, 2004
fvckin gl00b..
maybe you should have done it for him instead of making him look like a n00bular gl00b..
Lopes101
Jun 7, 2015 08:04 PM
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
TropiKalCiviC
Sep 25, 2001 07:02 PM
