Block Oil Pressure Sensor Cable
Old Sep 19, 2022
spudz904's Avatar
spudz904 is just really nicespudz904 is just really nicespudz904 is just really nicespudz904 is just really nice
2001 Civic EX. While changing my head gasket, I accidentally smashed and severed the electrical cable for the oil pressure sensor (above the oil filter on the block) between the intake manifold and its brackets. I'd repair the cable but I also happened to destroy the connector portion that plugs into the sensor itself. I can't find the part number, and several dealerships said they don't sell this part individually - it only comes as a part of the entire electrical harness apparently.
I tried sourcing one online without success; however, I might not be searching the right terms. Lots of different items being sold as oil pressure sensor/switch cable/connector. Aside from pulling one from a junk yard, does anyone have any idea where I might find this cable? Aftermarket maybe? If I can find the cable it should be easy to replace since the other side seems to just plug into a pin connector.
Credit to whoever took this photo.
Old Sep 19, 2022
Colin42's Avatar
Re: Block Oil Pressure Sensor Cable
Try rockauto, they list a bunch of different connectors
Old Sep 20, 2022
BrotatoChip's Avatar
Super Moderator
You could also grab one from a junkyard.
Dwnsyndromjr
Oct 9, 2021 02:06 PM
Thaik
Apr 12, 2012 05:48 PM
Blahman240
Engine Swaps
Jun 8, 2005 08:09 AM
Boilermaker1
Engine Swaps
Jun 22, 2004 04:49 PM
NoSpleeny
Jun 20, 2004 11:42 PM
