Oil pressure switch unplugged/ connector missing!
Old Apr 11, 2012
Thaik's Avatar
Thaik will become famous soon enoughThaik will become famous soon enough
As the title says, today I just found out that my oil pressure switch (sending unit for low oil pressure dummy light) was unplugged, the sensor right above the oil filter. I also realized the connector itself was missing and the connector on the sub-engine wire harness is missing too for that connector.
On the sensor, all I see is a cable with two wires at the end of it instead of a connector.
Does anyone knows where is the connector on the wire harness to that sensor?
Anybody done a recent oil change recently?
I've looked into a service manual pdf, and it says it is connected to the main engine wire harness.
Because of that, I now realized why I don't have have the "Low oil pressure light" on my dash.
Thanks
Old Apr 11, 2012
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Re: Oil pressure switch unplugged/ connector missing!
Thanks
its probably an aftermarket sensor for an oil pressure gauge someone had in it before you possibly.
Old Apr 11, 2012
Thaik's Avatar
Still, there should be a connector for it on the engine wire harness where that sensor connector is plugged in.
Any idea where?
I think it can be easily seen when replacing oil filter during oil change.
Old Apr 12, 2012
Thaik's Avatar
Anyone? Any clues here?
I'm sure you guys can help just by looking under the hood.
Blazz
May 25, 2015 10:56 PM
tmort
May 11, 2015 07:13 PM
usajags84
May 10, 2015 08:11 AM
Chronic_issues
May 8, 2015 05:40 PM
CarbonFiberSi
Apr 21, 2005 07:50 AM
