Electrical problem
Old Jan 20, 2020
Steve Gravitt's Avatar
Steve Gravitt is an unknown quantity at this point
Electrical problem
I'm helping a friend with his 2002 Civic. I'm getting 7.1 volts to the ELD no voltage to the 02 heaters looks like the alternator isn't charging either. He took it to a shop to get his cooling fans working there not getting power either same with AC they hooked up the fans to the heater wire to the 02 sensor.all the fuses inside and under the hood have power.
any ideas?
Old Jan 22, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Electrical problem
Does the vehicle have a code for o2 sensor or heater circuit?
If no other issues than I'd suspect the O2 needs to be replaced (if codes on). The o2 voltage is not constant on the heator, its governed by variable resistor. So you may see no voltage, if the resistance is not where it should be.
tyhochfelder
Oct 1, 2014 01:08 PM
NightOwl
Aug 23, 2013 03:54 PM
greeen01civic4d
Aug 26, 2009 02:59 PM
Hwoody77
Jun 19, 2006 10:11 AM
midnightblueEX
May 26, 2005 07:55 PM
