05 Honda Civic
Old Jan 21, 2020
JoeSippy's Avatar
JoeSippy is an unknown quantity at this point
05 Honda Civic
I just recently lost my tail lights in my 05 civic. The brake lights, hazard lights and turn signals all work and the spoiler light works with the brakes. I've check all fuses, both under steering wheel and under hood and I didn't see any blown fuses. I didn't see any breakage in any of my wiring. At least I didn't notice. I also changed the bulb. Did I miss anything? Any advice would help. Thanks
Old Jan 21, 2020
Colin42's Avatar
Re: 05 Honda Civic
Switch? Try jumping the contacts, there may be a relay, I'm not sure
Old Jan 22, 2020
BrotatoChip's Avatar
Super Moderator
Re: 05 Honda Civic
Do your headlights work?
Do your dash lights work when the headlights are turned on?
Old Jan 22, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 05 Honda Civic
You are referring to the outer tailights and not the trunk tailights? Or both?
The outer brake light bulbs are a dual-filament bulb for both functions as brake and taillights. Check that both filments in the bulbs are OK.
The trunk tailights are single filament.
Old Jan 22, 2020
JoeSippy's Avatar
Re: 05 Honda Civic
yes, both head light and dash board light are working.
Old Jan 22, 2020
JoeSippy's Avatar
Re: 05 Honda Civic
I'm referring to the outer light. The lights that are on at same time as the head lights at night time. I bought new bulbs thinking it was blown but same problem exist.
Old Jan 22, 2020
Super Moderator
Re: 05 Honda Civic
So the same spot as the brake light? As @NDNV suggested check both filaments. It's possible the bulbs you bought are only single filament.
Old Jan 22, 2020
JoeSippy's Avatar
Re: 05 Honda Civic
@BrotatoChip that's exactly what I did. I bought a single filament bulb and not a double filament bulb. Went to autozone and bought some and fixed the problem. Thanks all for your time and knowledge.
Old Jan 23, 2020
Super Moderator
Re: 05 Honda Civic
Glad to hear it was an easy fix
ninefivefour
Electrical
May 26, 2022 07:56 PM
Joethornton
Apr 1, 2017 11:09 PM
Smegmeg
Feb 14, 2014 07:42 AM
asdf123
Electrical
Jul 23, 2012 12:49 AM
xschizx9
Mar 8, 2005 04:14 PM
