03 civic windows
Old Oct 30, 2019
Garyg's Avatar
Garyg is an unknown quantity at this point
03 civic windows
Just installed a a/m stereo. I installed it in the stock location using a wire adapter. Tapped into a constant and accessory power. Also tore down the doors to install new speakers and in doing so had to disconnect all the wiring to panel. After reassembly , my power windows Windows would not work. I checked the fuses that I believe go to those switches and they were dead on both ends. Pulled the fuses and they look good. Put a test light to the fuse box without the fuses installed to see if there is power going to them and there were not. So now I have no power to either door window controls or to the fuse box. Not sure what I did while I was in there. I know what I didn't do and that was try to play it like I'm Superman and didn't disconnect the battery while I was in there. Not sure if I shorted something out or forgot to connect something so I opened them all up again. The dash and the doors. Couldn't find anything visual that I did wrong. Where do I go from here guys and gals?
Old Oct 31, 2019
BrotatoChip's Avatar
Super Moderator
Re: 03 civic windows
Let's start with the driver door. Check fuse 23 (20 amp) in the under-dash fuse box. You should have power to that fuse with ignition on.
Old Oct 31, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Check the backup fuse in the under-hood fuse/relay box. #9 (10A).
Also don't connect the illumination wire on an aftermarket head unit to the vehicle as it just creates problems.
Disconnect negative terminal from battery next time before installing head unit.
Old Nov 1, 2019
Garyg's Avatar
Replaced both fuses under the dash for the windows. Didn't know about the back up fuse under the hood. Sure enough, it was blown. Replaced it and the windows work as designed. Thank you all. I've been driving in freezing temps for three days with the windows down. I'm actually looking forward to the commute in the morning.
I allways thought the "back up" fuse was for the reverse lights. Duh!!!! What other circuits does it protect?
Old Nov 1, 2019
Super Moderator
The backup fuse is for:
Audio unit, Data link connector, Gauge assembly, Multiplex control unit, Immobiliser indicator light, Immobiliser receiver unit, Keyless receiver unit, Security control unit.
Pnutty209
Oct 23, 2012 06:40 PM
mattcoun
Apr 20, 2010 02:48 AM
kramner54
Jan 20, 2010 12:58 PM
Coors Light
Dec 7, 2007 12:33 AM
Imtheconvict
May 19, 2005 09:05 PM
