power sourse
Old May 17, 2005
Imtheconvict's Avatar
Imtheconvict has a little shameless behaviour in the past
power sourse
in there any way i can get power without a direct connect to the battery and without cuting any wires?
Old May 17, 2005
diskreet's Avatar
any empty spot in the fuse box, and that makes it very easy!
Old May 17, 2005
JP375's Avatar
JP375 is an unknown quantity at this point
oh, good god
Old May 17, 2005
ok so if theres an empty slot can i still fuse it or do i need a inline fuse what do i do
Old May 17, 2005
ajhdragon's Avatar
7thgens official a$$hole
inline
Old May 17, 2005
paradoxblue's Avatar
wait.. wut are you running?
also u can pop out the cig lighter thinger.. and pop off the plugs and cram the power wire under there.. thats wut i did for some lights.. they only get woer when car is on
Old May 17, 2005
diskreet's Avatar
if using the Fuse panel then you have to add a fuse in the panel to get power to it; so no other fuse on the wire. otherwise inline fuse
Old May 17, 2005
jjdawg22's Avatar
jjdawg22 is an unknown quantity at this point
source*
Old May 19, 2005
jttegx's Avatar
OMNES AD UNUM
imtheconvict, what are you trying to power?
hope not your power wire for an audio system
Old May 19, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Guess he's not too anxious for his answer . . . .
Old May 19, 2005
nope just neons i ended up fuseing them 2 the fuse box on an empty slot
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
kmarcet
Sep 26, 2015 10:25 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
