No power to stereo, please help!
Old May 4, 2009
kramner54's Avatar
kramner54 is an unknown quantity at this point
i have a 1989-1991 Honda Accord Ex
i was recently installing a stock s2000 head unit into my car, because it had a broken led with the stock. when i was installing, i forgot to get the anti-theft from a friend which took maybe 30-60 mins trying to get. forgetting to remove the head unit, and coming back trying to turn it on agian. the power did not come. then trying to put the stock unit, no power again was happening, so i popped the hood, check the back up radio fuse, and it was a 7.5A burnt, i didnt have a 7.5 on me but i did have a 10A. assuming that would help popped in the unit again no power. so i borrowed a 7.5A fuse from a friend, and still no power to both the stock unit, and the new one. can anyone help. i went to best buy and another place called progressive, and it would cost 20$ per 15 min diagonstics, which could lead to huge waiting.. is there another fuse box i should be aware of, if so where, please again help. it sucks driving around without a radio, it kills! thanks in advance.
Old May 5, 2009
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: No power to stereo, please help!
Not 100% positive but there should be a fuse box in the passenger cabin. I would check under the steering column and once you find the fuse panel, look for another blown fuse. It will possibly be labelled radio but most likely it will be a horn fuse, dash light fuse, something else altogether. If there are any lights that haven't been coming on, check for those fuses as well.
Another thing is if you modified the stock harness at all you may have pulled a wire loose or maybe cut a wire by accident. You're best bet is: check for fuses, get a fuse tester if you want, replace any and all bad fuses, check the radio again, test each of the important wires for power during the on position: backup, ACC, and ground. If all else fails check the fuses in the radio.
Old May 5, 2009
electric130's Avatar
never, NEVER, replace a fuse with a larger one. fuses are sized to protect the wires. if you put a bigger fuse in, you'll draw more current than the wire can take. the wire heats up and possibly causes a fire.
did you check the "back up" fuse under the hood?
Old May 5, 2009
Double Post FTW, lol. But yeah that was the fuse he replaced with a larger one. Even if the backup fuse is blown, I have known plenty of stereo's that still work, they just don't store time, stations, and settings.
Old May 5, 2009
man, my computer's been doing that all day. don't know why. Dell's suck!
Old May 5, 2009
Lmao, I hear you on that. But don't feel too bad, I post on civicforums using my HTC phone and I double post a lot too.
Old May 6, 2009
caryseo's Avatar
caryseo is an unknown quantity at this point
That's a great help...
Old May 7, 2009
Are you being sarcastic or did you actually get it to work? I also had another post further up telling u some things to try.
Old Jan 20, 2010
fozzyozzy's Avatar
fozzyozzy is an unknown quantity at this point
the stereo in my car stop working. no lights, nothing. where is the fuse box for honda civic 2003? so tha i can check if the fuse has blown.
Old Jan 20, 2010
one under the steering wheel and one under the hood.
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
sch2cm
Jul 21, 2015 09:58 PM
breanna_17
Jul 21, 2015 04:01 PM
robbie374
Jul 7, 2015 02:56 AM
