04 civic SE new battery is leaking
Old Aug 17, 2019
RRay's Avatar
RRay is an unknown quantity at this point
Hi guys,
I have a 2004 honda civic SE.
I just started my car today after a day without using it and the battery light came on in the dash.
I decided to check the battery and saw that it was leaking acid a lot.... I change it for a brand new one which is leaking too.
My battery light still on in the dash too.
Can it be my alternator that is overcharging my battery ? I changed it 2 years ago.
Help please
Thank you
Old Aug 18, 2019
Colin42's Avatar
Re: 04 civic SE new battery is leaking
Need to measure the voltage at the battery with the engine running. should be around 14 volts if it's significantly higher then the alternator is over charging
Old Aug 20, 2019
RRay's Avatar
Thanks for the tips !
Turns out that the voltage at the battery was around 18 volts ! I changed the alternator and everything is fine.
Old Aug 20, 2019
Colin42's Avatar
GERRYC
Jul 30, 2012 03:43 PM
Goonth
Feb 21, 2011 05:22 PM
JayG523
Jan 14, 2007 02:12 PM
1stcivic
Apr 22, 2005 02:31 PM
mrchowmein
Jan 25, 2005 05:07 PM
