7th Gen Electrical Issues
Old May 30, 2019
Don_1's Avatar
Don_1 is an unknown quantity at this point
D17a1 2004 Lx. Fans turn on when ever I use the power windows or apply the brake when the key is in the on position. The car also cranks but wont start. What can cause this? Bad relay maybe?
https://drive.google.com/file/d/1c6eiwZgekvZC2NG_phhvac59nETGTFOS/view?usp=drivesdk
Old May 30, 2019
BrotatoChip's Avatar
Super Moderator
Re: 7th Gen Electrical Issues
When I see odd electrical issues the first thing I check is grounds. If a ground wire was missed electrical components may end up grounding through another component.
Old May 30, 2019
Don_1's Avatar
All the grounds are connected from what I can tell. The car ran fine yesterday. I went to start it this morning. It turned over but doesn't start. I checked the fuses, they all look fine. Next i checked the pgm-fi 2 relay behind the glove box. There is a clicking noise when I wiggle it. When it is removed the fans no longer turn on when i press the brakes or mess with the power window. Im having a new relay picked up. Hopefully it fixes my issues.
anotherD3MISE
22
Jun 29, 2017 05:44 AM
Chickenhawk327
Oct 4, 2014 02:37 AM
td1238
Mar 9, 2012 12:12 PM
babzog
Mar 18, 2009 06:39 AM
Kirbert
18
Jun 26, 2007 10:52 PM
