My dome light in my 7th gen civic isn’t getting power
Super Moderator
Received 1,848 Likes
Rep Power: 196 Re: My dome light in my 7th gen civic isn’t getting power
I'm assuming you don't have a sunroof, correct?
Do the map/spot lights up front work?
Super Moderator
Power and ground are shared between the front map lights and the dome light, that helps pinpoint it to something with the dome light specifically. You have no power at the dome light, next I would remove the dome light/switch assembly and check for power/ground in the connector.
civic1993driver
06-16-2014 01:44 PM
