Everything BUT the actual gauges and “D” light on cluster work!
Old May 29, 2019
MartianMan's Avatar
MartianMan is an unknown quantity at this point
Hi, so i recently purchased a 2001 Honda Civic Lx Coupe and I noticed that the gauge lights don’t turn on when I turn on my light switch... my stock radio illuminates, my climate controls illuminate and my headlights turn on. The dimmer is all the way up! and yes it does work. Everything on my cluster works except the actual gauges themselves don’t light up (RPM, Temperature, Speed, and Gas Level). I’ve checked my fuses (but I’m always up for double checking) they seem fine, both inside the cabin and under the hood. Is it the bulbs ? I will be installing an after market headunit shortly after I post this so please take that into consideration when trying to answer my question. Also my “D” is out. I’m in need of help.
Old May 30, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Everything BUT the actual gauges and “D” light on cluster work!
Previous owner may have had an aftermarket audio unit and fried some circuits connecting the illumination wire. If you are installing an aftermarket radio don't connect the illumination wire.
You can check wire harnesses for poor connections and for faulty bulbs in the gauge assembly.
Check the #4 (10 A) fuse in the Under-Dash Fuse/Relay Box and #2 (15 A) and #9 (10 A) in the Under-Hood Fuse/Relay Box.
Old May 30, 2019
MartianMan's Avatar
Thank you! I’ll be trying this today. I will be replying back if nothing has worked.
Kaleemsgarage
Electrical
Oct 4, 2019 06:16 AM
s1ayermonkey
Oct 17, 2017 09:23 AM
civicplaya
Buy, Sell, & Trade - Archive
Apr 27, 2009 03:03 PM
Ford
Jun 18, 2008 03:10 PM
manofaction09
Sep 11, 2006 11:54 PM
