Car won't start unless I turn wheel
Old Dec 3, 2018
dkpeace's Avatar
dkpeace is an unknown quantity at this point
I have a 2003 Civic ex. When I put the key in and turn it, it will click and the lights will come on, but it won't turn crank. Then, if I turn the wheel a little bit, it will actually start. The wheel isn't locked up, and will actually turn. The battery and alternator are both good. I'm assuming it's something in the ignition or starter, or possibly some sort of short or loose wire, but I want to figure out a way to definitively diagnos it before I start buying parts and what not.
Thanks for any help
Old Dec 3, 2018
Colin42's Avatar
Re: Car won't start unless I turn wheel
something wrong with the wiring in the steering column, ignition switch may be bad, pop the covers off and start looking. do you have a test light or a multimeter?
Old Dec 3, 2018
dkpeace's Avatar
Yeah, I've popped the covers off and check for loose wires and didn't find anything. I have a test light and a multimeter. I've never actually tried to diagnose this type of problem though, so I don't know what to check.
Old Dec 11, 2018
dkpeace's Avatar
So, this morning, after I drove to work I tried to start my car again, and it wouldn't start. Then instead of turning the wheel at all, I took the key out and flipped it over and put it back in and it started up. Is it possible I just need a new key or something?
Old Sep 1, 2022
silky85282's Avatar
silky85282 is an unknown quantity at this point
Ho, I’m having the very same issue. Did you ever find a solution?
Nascarfan88
Engine start problems
Mar 5, 2019 02:47 PM
jshalala
Jan 1, 2012 10:20 PM
slicksivik
Jan 7, 2007 12:08 AM
brandonhhh
Apr 26, 2006 07:36 PM
rokenrolcivic
Jan 31, 2004 10:25 PM
