Do I need a new Ignition Switch? Im stuck!
Old Sep 20, 2011
jshalala's Avatar
jshalala is an unknown quantity at this point
Hey everyone. Im new here and have a quick question. Last week I bought a 98 Honda Civic EX coupe from a friend. Vin code 6. d16 with the 5spd. fairly clean but doesnt run. Hasnt ran in almost a year, just sat on the side of the road. He lost the key, so when I towed it up here I took the title in to the dealer and they cut me a new one. It goes in the ignition and you hear the "beep" but it refuses to turn. My steering wheel is locked and because I cant turn the key I cant unlock the steering wheel to move the car around my shop. I had another one cut, and then made a copy if it at the hardware store and it still wont turn. Question: Is there any way I can bypass the ignition so I can at least unlock the steering wheel so I can turn the car and push it where I need it to go? I saw on ebay there are so re-keying kits for EVERYTHING but Im hoping there is a trick to getting the ignition "unstuck"? Once I get that stupid problem out of the way then I can work on getting it up and running lol Thanks again for reading this book and let me know if you have any ideas.
Old Sep 20, 2011
jshalala's Avatar
Re: Do I need a new Ignition Switch? Im stuck!
One more thing. If there is anyone around the Akron/Cleveland, Ohio area Im looking for a d16 engine for this car. Previous owner took it to his mechanic after throwing a million parts at it and the mechanic said it has no compression in cyliner one. 196k on it. So I would rather find a running d16 to drop into it instead of trying to fix this one. I dont care about miles, just want it to run. Thanks again.
Old Oct 12, 2011
cody-james's Avatar
cody-james is an unknown quantity at this point
Having the exact same problem. I bought car with lost key. After having one made it wouldn't start. I just replaced the ignition switch today (fairly easy) but now it only cranks and won't start. did you ever figure anything out?
Old Oct 19, 2011
johnny3's Avatar
johnny3 is an unknown quantity at this point
Try turning the key while turning the steering wheel back & forth with consideral pressure, sounds like the steering wheel locking mechanism may be in a bind.
Old Jan 1, 2012
jshalala's Avatar
I just ended up replacing the entire ignition switch assembly for one from RockAuto, it came with keys and all the wiring for around $60 bucks. Easy to install and it starts great now.
Old Jan 1, 2012
jshalala's Avatar
Sorry I dont get notification emails of new posts got to change that. Did you figure this out yet? I was going to say if its cranking now but not starting the ignition switch would not be the problem as it is doing its job
Hqly2001
22
Jul 12, 2015 06:44 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
