Headlight Clip Help!
Old Feb 25, 2007
Monika's Avatar
Monika is an unknown quantity at this point
So I'm replacing my headlight bulbs in my 2k1 Civic, and the driver's side replacement goes fine, the passenger replacement doesn't go so well.
I'd been in a fender-bender a while ago and my passenger side headlight isn't the same year as my driver's side. It must be a 2k2 or 2k3 headlight, or something. As I pull off the rubber thing, the clip just falls out so I have no idea how the clip goes back in.
I've done some searching, and maybe I'm not using the right terms, but I can't find any info on how it fits back into the headlight.
Does anyone here have a photo or a diagram of how the clip is supposed to sit inside the back of the headlight?
Thanks!
Old Feb 26, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
I believe that if it is a Honda headlight it should be the same for years 01 to 03. The clip should be reinstalled similar to your driver's side light, might be backwards or mirrored.
Old Feb 26, 2007
Monika's Avatar
Then the new headlight must be an 04, cause the retaining clip looks a lot different than the headlight that came with my car.
But I got a diagram from a friend, and my new bulbs are installed
Old Feb 26, 2007
AmbulanceMonkee's Avatar
^if you had an 04 headlight on an 01, you'd know it. it's probably not an oem light.
Old Feb 26, 2007
bobsagator's Avatar
04/05 headlights won't fit on 01. Glad you figured it out.
Old Feb 19, 2020
Erin Barnes's Avatar
Erin Barnes is an unknown quantity at this point
Exclamation Re: Headlight Clip Help!
can you share the Diagram?
Old Feb 19, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Probably not as the last post from this person was 13 years ago...
Does the first minute and a half of this video help?
charmon4815
General
Sep 22, 2015 08:00 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
