Brakes Post your questions about Brakes problems here!
Loud brake noise [solved]
Old Aug 13, 2022
macaufan's Avatar
macaufan is an unknown quantity at this point
Heard loud brake noise usually after 10 miles of driving. Took it to the dealer and had it checked twice but couldn’t find any problems. Dealer had the disks sanded. Also weird/whining noise when in low speed. Anyone knows what the issues are?
Old Aug 13, 2022
Wankenstein's Avatar
re: Loud brake noise [solved]
What type of noise? Can you capture it on video and post it here?
Old Aug 15, 2022
macaufan's Avatar
Here you go
File Type: mov
Old Aug 16, 2022
macaufan's Avatar
How the brake sound
File Type: mov
Old Aug 16, 2022
Originally Posted by macaufan
Here you go
Sounds like metal on metal noise. How many mile ago were the brake pads replaced? Could be pads need replacement or lubed at points other than where they contact the rotors.
Might be they brake caliper pins need to be re-lubed or replaced? Some of those pins are designed with a rubber ring that can wear out over time.
Brake noise like that can be intermittent and hard to track down even when they are constant. Sometimes it has to do with brake pad materials and who manufactures them.
Old Aug 17, 2022
macaufan's Avatar
I just bought this used car 2 months ago. Dealer checked and said that the pads were just replaced. Front pad at 70% and rear at 90%. Thanks.
Old Aug 17, 2022
macaufan's Avatar
Dealer said the same thing saying that the pads were meant to be used on tracks and little dust would also cause this kind of noise. I’m not sure what they say are true or not.
Old Aug 17, 2022
Did the dealer mechanic say what type (ex: ceramic, semi-metallic) of brake pads they are? Did they mention slotted or drilled rotors?
It's likely that they are cheap pads purchased at an auto store or are not the factory brake pad type (ex: ceramic, semi-metallic) and material. Here's https://www.hondapartsnow.com/genuin...2-tba-a00.html what looks to be the oem model number and you can input your VIN to verify. HondaPartsNow is a reputable dealer of Honda Genuine (OEM) parts. I have purchased from them many times and always solid quality and prices.
You may want to continue using the current pads and see if the noise eventually goes away. However, incorrect pads can cause premature rotor wear. You may want to try a brake pads bed-in procedure to hopefully improve the noise. Here's a link to a general bed-in procedure https://www.autozone.com/diy/brakes/bedding-brakes.
Old Aug 17, 2022
are the wheels getting dark with dust?
Hawk pads for street are noisy and leaves a lot of dust
Old Aug 19, 2022
macaufan's Avatar
ok I’ll try thank you
Old Aug 19, 2022
macaufan's Avatar
yes they are
Old Aug 19, 2022
yes they are
then you have one of those high friction pads. Hawk or similar. They wear faster and release a lot of dust, so check then every once in a while.
Old Aug 23, 2022
macaufan's Avatar
Re: Loud brake noise [solved]
Ok thank you
Vinnie
18
Mar 29, 2006 01:38 PM
Tronixx
Oct 14, 2005 06:44 PM
waross
May 21, 2005 01:57 PM
