General Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
2019 Honda Civic 1.5T – Multiple system warnings + engine codes (151k miles)
Old Jan 12, 2026
powell601's Avatar
powell601 is an unknown quantity at this point
I’m getting a bunch of warnings all at once:
  • Adaptive Cruise Control problem
  • Collision Mitigation System problem
  • Road Departure Mitigation problem
  • VSA / Brake System / Brake Hold problem
  • EPS (power steering) problem
  • TPMS problem
  • Emissions system problem
Scan tool results:
Engine:
  • P2187 – Fuel system too lean at idle (permanent + temporary)
  • P0299 – Turbo underboost (permanent + temporary)
Other modules:
  • U0416-68 – VSA system malfunction / brake actuator
  • P2583-76 – Radar misalignment (Integrated Driver Support System)
  • U0401-68 – ECM failure (communication related)
Symptoms:
  • Car stalled right after starting once and hesitated to restart
  • Acceleration feels weaker than normal
  • Power steering warning came on
  • All driver assist features disabled
Battery tested good. Charging voltage stays above 14V while running.
Radar/ACC errors started first, then the engine codes and everything else followed.
Looking for ideas on likely root cause (vacuum leak? boost leak? sensor? wiring?) and what to check first.
Thanks in advance.
Old Jan 14, 2026
Colin42's Avatar
Re: 2019 Honda Civic 1.5T – Multiple system warnings + engine codes (151k miles)
If the battery and alternator are good, then i would think its something with the wiring
Old Jan 16, 2026
no jokes. squirrels make a mess with wires...
Mig21
Electronics
Oct 31, 2021 02:10 PM
xRiCeBoYx
General 10th Gen
Jul 27, 2021 06:56 PM
01SedanLX
Jan 2, 2004 06:32 PM
