TECH Question: Is the door signal (under the dash) strong enough to power these?
Old Apr 14, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Well someone wants these
to be lighted up when door is open. Now I know how to test which wire under the steering column, but you think it's strong enough to power these? These are 12volt BTW.
Old Apr 14, 2003
Booohahaha's Avatar
BAD MON
wire it up and if it turns on like normal then u know it will work
Old Apr 14, 2003
AzimuthX's Avatar
Can we use your sunfire to test it? I need access to undercolumn, and a test light to see which one is the doors.
Old Apr 14, 2003
Blkcivic's Avatar
my friend has done a similar thing to has accord and it seems to be a bit weak! not sure WTF he did
Old Apr 14, 2003
DragonAce's Avatar
DragonAce is an unknown quantity at this point
relay off the battery and use the door switch as the ground??
Old Apr 14, 2003
AzimuthX's Avatar
RELAY? I don't know how...
Old Apr 15, 2003
R1Style's Avatar
lol....
Run the Positive wire to the battery.
Run the Negative wire to the ground wire for the door switch.
Also... buy a voltmeter if you wanna test how much current certain wires are running off. Most wires should be running 12v anyways.
Old Apr 15, 2003
chanpakto's Avatar
chanpakto is an unknown quantity at this point
I agree, this is probably the best way to do it.
Originally posted by R1Style
lol....
Old Apr 15, 2003
AzimuthX's Avatar
How do I run it off the battery, its 12v because thats the voltage of the dome bulbs, its the current that matters. The wire under the steering column is positive though... hmm help?
Old Apr 15, 2003
mohawkboom's Avatar
Oh man..you have to wire neaons right to the battery or the fuse panel..perid. You can use a relay to the door ground switch, but it needs it's own ground. The wiring in the civic is all 18 or 20 guage and is too small to support that much current draw.
Old Apr 15, 2003
R1Style's Avatar
Honestly, not to be rude but I don't think you should do this by yourself. It seems like you've never done anything like this before. Get a friend or someone who knows what they're doing to help you.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
MamaBear2015
May 3, 2015 02:17 PM
Fastfebur
Apr 22, 2015 01:37 PM
darwin-t
Apr 18, 2015 09:29 PM
SSMatey
Apr 13, 2015 06:09 PM
