crummy ass factory battery
crummy *** factory battery
has anyone else had problems w/ their battery? i had to have my replaced and honda said it would not be covered under warranty b/c ihave an aftermarket alarm and a system.
Quote
[hr]Originally posted by: riceboi
has anyone else had problems w/ their battery? i had to have my replaced and honda said it would not be covered under warranty b/c ihave an aftermarket alarm and a system.[hr]
but i once i rev it...the light is brighter...i had a system.... b4.... but i took that out already..
it's probably because my pulley..that's why
Yes, it's an Acura EL
If you're concerned about the lights dimming when you're not revving, that's your charging system (ie alt/pulley). I'm still investigating a new alt, cause ours give so little current. I want a 150A one! Dammit!
Honda batteries are very very good compared to what alot of other cars get.
The only thing that causes a battery to go prematurely is a short or stupidity.
If your cranking your system when the cars idling you can start draining down the battery. If a regular battery gets drained to half Capacity or lower, it'll never hold the same amount of charge again. and it''s life expectancy will go to s**t.
Deep cycle batteries are made so that they can be heavily discharged and recharge over and over without problems.
If you had a short and no blown fuses and your car never caught fire..that's a miracle [IMG]i/expressions/face-icon-small-smile.gif[/IMG]...
You prbably overworked the battery and discharged it too much and it couldn't recover...=stupidity... I'm not insulting you but whenever I do things like that..which I've done I always want to slap myself for being a dummy.
over working the battery may have a little to do with it but on short drives, i try not to crank it.
but anyway ive got a deep cycle yellow top now so hopefully all should be good
Just got a new battery today from sears.Mine's not even 2 years old (21500 miles)and it wont stay charged.Got to use a booster pac every f#c@i*n% morning for a week to check if it would get charged before getting the new battery.Shouldn't be spending money on batteries these early on a 2 year old car..
i need to replace mine soon......
how much do they charge at the dealer...
i have close to 50000km and my car die a few times....
cause no battery..... had to use booster from my frds...
i took out my system already....but i still have the pulleys...
Originally posted by BJAI
and i can see the light in side it's not as bright...
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
