noise while turning my steering wheel...
Old Feb 13, 2005
AznSaint's Avatar
AznSaint is an unknown quantity at this point
lately... in the past month.. it has happened about three times. while i turn the steering wheel.. i would notice a squealing noise... not from the steering wheel... but from the wheels... or at the middle point from the steering wheel to the two wheels.
it's a very disturbing noise... anybody have any clue of what it is?
does a certain part need lubrication...?
and another question.. how long does the standard warrenty last for again..? without the extended warrenty.........?
3years/60,000km??
im at 66km's already.. 2years 6months...and if i needed something replaced.. i definitely dont want to chuck out money for it.......
Old Feb 13, 2005
MIR's Avatar
MIR
~Your Favourite CiViC GiRL~
MIR is an unknown quantity at this point
ok ya i think this mite be the same thing i experienced last winter, one of two things
i used to get a squeeling noise in wet weather and so on (belts had to be tightened, adjusted whatever)
i used to get creaky/squeeling noises turning and so on, the strut bar or something had to be replaced but it was free cause of warranty and cause they have had lotsa problems with them blowing the seal or something...
not sure if this is the same thing, but some input anyway..
Old Feb 13, 2005
infinite's Avatar
infinite is an unknown quantity at this point
it could be many things. first off, is your car lowered? lowering can often cause undesirable noises from the suspension in some cases this is normal. blown struts and cracked bushings are two possibilities. i've heard of someone cracking the lower control arm due the car being too low to the ground combined with wreckless driving. if the noise is not causing any problems with the handling of your ride i'd just leave it alone.
Old Feb 14, 2005
KDawg88's Avatar
KDawg88 is an unknown quantity at this point
I had a similar problem in an older civic, but the noise seemed to be coming from midway in the steering column. In the end, it turned out to be my horn contacts...just got the shop to lube them up for a couple of bucks and it was fine again.
Old Mar 7, 2005
ADS's Avatar
ADS
ADS is an unknown quantity at this point
It could be the strut tower plates after i lowered my car i had to have them replaced....one side is more than the other gotta love honda
Old Mar 7, 2005
Transformer_Guy's Avatar
Lost in the Matrix
Transformer_Guy is on a distinguished road
This may sound stupid but it could be snow build up on the mudgaurds. My moms car made a similar sound when there was a buildup of thick ice preventing the tires from turning all the way
Old Mar 7, 2005
ADS's Avatar
ADS
Good call tim it also could be a piece of junk from the road caught in a suspension component....get the car off the ground and look at it and see if the solution is simple
Old Mar 7, 2005
AznSaint's Avatar
thx for the replies
it is now early march......... dont believe i hear the sound no more...
i guess it could of been ice build up.... b/c it was around the time when the weather got really really cold.
Old Mar 7, 2005
Lost in the Matrix
OMG... I might have actually been right??? I'm scared!
Old Mar 8, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Now, now timmy.. We all know you are a genius
Old Mar 8, 2005
Booohahaha's Avatar
BAD MON
ooooO...i haf this same problem
i usually only hear it when its cold
Old Mar 8, 2005
astrosi's Avatar
astrosi is an unknown quantity at this point
does anyone have any problems when there makin a right hand turn at slow/high speed and u can hear noise's like "cluck cluck" sounds cause mines does that ... i was wondering if its the driveshaft?
rtachs
Jul 16, 2015 05:32 PM
trellex
May 24, 2015 04:39 PM
anddrrey
May 11, 2015 02:30 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
