Hole for sidemarkers
Old Mar 17, 2004
Blkcivic's Avatar
Does neone know how to cut out the hole to install side markers? i went to home depot/ canadian tire and radio shack and they don't have nething that can do the job.... can't neone help me out or recommand a shop that can help me out?
Old Mar 17, 2004
flip114's Avatar
flip114 is an unknown quantity at this point
I've seen a DIY on this somewhere before. I remember the person used a sheet metal hole cutter (from home depot or radio shack) to punch the hole for the sides markers.
Are they like VW Passet side markers where they sink in or the side markers that go on top of the body?
Good luck!!
Old Mar 17, 2004
You need sidemarkers that cover the hole, otherwise it won't look good. I drilled a small hole big enough to fit the sheet metal nibbler in. You can pick up the nibbler from radioshack. They carry it for sure. It's a tool like pliars that cuts small squares of sheetmetal.
Old Mar 17, 2004
player's Avatar
i put mine on the side of my bumper, i used a drill bit the ones that me circles and my marker had a circle in its behind that goes into the drilled hole.
Old Mar 17, 2004
TeLLy's Avatar
Yes, it's an Acura EL
My friend used a dremel at his shop. Well actually first he used a huge *** drill to carefully drill a couple of holes in each side in order to have something to cut from. Then he hooked up his dremel and started cutting. But then his dremel broke. He went out to get a new dremel (left me in his shop alone with nothing but a bunch of import mags). Finished the job, like 4 hours later. The new dremel cut through my fender like butter. So I bought it off him. Now I have a dremel.
Our fenders are soft, so be careful drillin the first hole, it's real easy to punch a dent into the metal. Oh and the sound of a dremel cutter bit hitting sheet metal is real heartbreaking when you know it's YOUR car....I swear I wanted to cry when I heard it. So I went outside and quietly let the tears roll down my face...
Old Mar 17, 2004
player's Avatar
also, try to cover the edges of the hole with tape or some touch up paint to stop rust from forming
Old Mar 17, 2004
Oh yeah, that's very important. Touchup paint or some anti rust spray, or you'll have major problems. Go easy on the sheet metal, or you'll have dents all around where you cut.
Old Mar 18, 2004
jongreenway's Avatar
jongreenway is an unknown quantity at this point
Go to a shop. I had mine done at the Cockpit in mississauga.
Old Mar 18, 2004
TeLLy's Avatar
Had mine done at Proparts (formerly known as Speedbump) in Mississauga. He was even nice enough to apply touchup paint around the edges for me.
Old Mar 18, 2004
Blkcivic's Avatar
how much did it cost u guys?
Old Mar 18, 2004
TeLLy's Avatar
Got mine for like a bill.
Old Mar 19, 2004
Liro's Avatar
Back from the dead
i think it'd be a good idea to have the shop drill the holes so they can spray the exposed metal to help prevent rusting, that or find out what spray they are using and get it yourself
Old Mar 19, 2004
E®ik's Avatar
E®ik will become famous soon enoughE®ik will become famous soon enough
Player.. what language you speakin bro!
jokes
Old Mar 19, 2004
Dasica's Avatar
Dasica is an unknown quantity at this point
Couldn't you use metal hole saws, (the one with the drill bit that goes into a bigger round saw) they sell them at Crappy Tire. I use them all the time to cut into metal, but never used it on cars. But I'd just take it to the shop just wondering if anybody ever used those before.
Old Mar 19, 2004
You will ruin your side panel with that. Even with the tiny sheet metal nibblers, I was starting to get dents along the edges. Just follow the DIY and you'll be fine. Here's one I did a while back.\
http://www.7thgencivic.com/forums/sh...sidemarker+diy
Old Mar 21, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
we use diamond dremel bits, a little expensive but they work the best i haven't broke one yet.
Old Mar 21, 2004
COst me $56
jdh022764
18
Nov 3, 2015 06:44 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
Islesfan
Sep 29, 2015 03:42 AM
jsmithe2010
Sep 25, 2015 07:42 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
