help! bulbs are out!
Old Jan 1, 2003
Jodster's Avatar
Post Whore General
Last night I was going to go pick up my girl from work and my head lights would not work. I have a set of super white bulbs. I've had them for a about 9 months and there not working anymore. Its only the low beams. The high beams work fine, but the lows are out. Could it be a wiring problem or are my low beams burned out?
Old Jan 1, 2003
666's Avatar
666
666 is an unknown quantity at this point
It's a good chance they are burned out. I have gone through many sets of aftermarket bulbs claiming to be super white or ultra white and no matter what brand you buy they all seem to burn out within a year.
Old Jan 1, 2003
cambo's Avatar
I wish I was asian
did u take them out and look at them? thats the first thing u can do to determine whats the problem.
i would think that they're burned out or u fried ur wire harness.
Old Jan 1, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
replace the bulbs
INJEN
Old Jan 1, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: Jodster
Last night I was going to go pick up my girl from work and my head lights would not work. I have a set of super white bulbs. I've had them for a about 9 months and there not working anymore. Its only the low beams. The high beams work fine, but the lows are out. Could it be a wiring problem or are my low beams burned out?[hr]
Normal. What brand are the light bulbs? If they are cheap or unknown ones, 9 months seems pretty good.
Anyway, H4 = double filament. Meaning even if you burn ur low beams, your high beams still work because they are another filament. Ok bad wording, but yea..
Just replace your bulbs with PIAA's or MTEC's
Old Jan 1, 2003
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
1 of my bubls went out in almost a yr
then one of my fog lights went out...but i think it just came loose
urs r probably just burnt...get new ones
Old Jan 1, 2003
slowasscivic's Avatar
slowasscivic is an unknown quantity at this point
after the 2nd time my piaas burn out i just purchased a true hid kit...now i am very happy
Old Jan 1, 2003
btw my passanger side blew out three times in nine months (yes i was using the correct wattage bulbs)...god dayum...thank god for year warranty from piaa
Old Jan 1, 2003
Jodster's Avatar
Post Whore General
ok I put my stock head light bulbs back in and the low beams still do not work! I checked all of the fuses and they look all ok. But I don't know if the big fuses for the head lights are out or not. What do I do now? Is it a wiring problem or a fuse problem?
Old Jan 1, 2003
blk2k2civic's Avatar
Banned For My Beliefs
blk2k2civic is an unknown quantity at this point
And of course try not to touch the bulb itself I did that and it cut the bulb life in half
Old Jan 1, 2003
XxJDMCivicxX's Avatar
while installing use kleenex this way you won't get any acids from your palms or whatever reacts to the gas in the bulb it's the best way
Old Jan 1, 2003
Gryphin's Avatar
00 Hatchback Owner
Quote
ok I put my stock head light bulbs back in and the low beams still do not work! I checked all of the fuses and they look all ok. But I don't know if the big fuses for the head lights are out or not. What do I do now? Is it a wiring problem or a fuse problem?[hr]
you have a problem, you fried your wiring harness , becaused if your high beams work but you low beams down no matter the bulb then its the wiring to the housing
cferry7
Oct 18, 2015 06:32 PM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
mac25
Aug 21, 2015 11:14 PM
j-chest
Aug 11, 2015 02:26 PM
