HELP MISSING LINK install!!!!!!
Old Dec 9, 2002
MrCool's Avatar
MrCool is an unknown quantity at this point
where dose it go in front of the throttle body or right side left side back looks like to me in the front but there is something blocking it so it would b impossible to install the fuel rail would b in the way so it wont fit? help wehre dose it go and how to install!
Old Dec 9, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
It goes in the trunk!!
J/k
Tell me what the hell you're talking about and I'll try to help.
Old Dec 9, 2002
MrCool's Avatar
its for a turbo goes to trick map sensor but i dont know exactly to put it thanks
my whip
Old Dec 9, 2002
AEMcivic's Avatar
So you're tryin to install a check valve for your map sensor right?
Old Dec 9, 2002
MrCool's Avatar
yeah thats right
Old Dec 9, 2002
AEMcivic's Avatar
I haven't installed one on a 7thgen, but usually you just unscrew the map sensor, place the check valve under the map sensor, and screw it back in.
Old Dec 9, 2002
Grey's Avatar
DIY King
Just curious, which model did you buy? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 9, 2002
Mbow's Avatar
Offtopic: I don't know how any of you know/knew what the heck he was trying to say.
Old Dec 9, 2002
MrCool's Avatar
its the one on the web site for a 92 and up civic looks like 2 triangles put together with screws that go through on each side
Old Dec 9, 2002
Grey's Avatar
DIY King
Yeah, that is the right one to use. See the installation instructions... Installation Instructions It's pretty easy. The MAP sensor is to the right in this picture...
The front thing by the fuel rail is the TPS (Throttle Position Sensor). The thing to the left is the IAC (Idle Air Control Valve). It's somewhere to the right there, just don't know where for sure...
Old Dec 9, 2002
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
Quote
[hr]its the one on the web site for a 92 and up civic looks like 2 triangles put together with screws that go through on each side [hr]
i dont think you can use that one.only one screw is holding ours down and its shape as a square.you might be able to use the other type and do what AEMcivic said.
Old Dec 9, 2002
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: CIVIC808
Quote
i dont think you can use that one.only one screw is holding ours down and its shape as a square.you might be able to use the other type and do what AEMcivic said.[hr]
You know this for sure? I heard from RiceBurner (the dude with the turbo) that he used that one. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
jbdewitt
Jun 16, 2015 01:36 PM
carid
Jun 10, 2015 09:57 AM
Vanman
Jun 9, 2015 08:17 PM
cooldan1
Apr 23, 2015 10:49 AM
usajags84
Apr 10, 2015 09:54 PM
